Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Sonics Box
Old 05-22-2005, 23:40   #1 (permalink)
Member: 146818
Thanks Meter: 7
sonicsbox killed my v800
i have a v800 with the unstable system, then i used sonicsbox to flash my v800, after flash the main file and fs file, the phone can't be turn on and i have been trying many different firmware, but all at the end just come up a msg " warning: this is failed, this is a fatal" can any one help for this? MANY THANKS!!!!!!!!
Old 05-23-2005, 09:52   #2 (permalink)
Member: 38039
Thanks Meter: 6
Hi,
Download v800_RED_EROM firmware file from SONICS SUPPORT SECTION,
unpack it, then select it in "main firmware file" field and press FLASH FILES, after it phone can be powered on.
(If "Configuration error" occurs, re-flash MAIN + FS with "brand after change lang" ticked.)
Note: Be sure the battery is fully charged.
best regards
Old 05-23-2005, 10:07   #3 (permalink)
Invisible's Avatar
Member: 3956
Sonork: galletto3 rules :D
Thanks Meter: 55
hi
yes, v800 are commond to go in that problem a lot when flashing main software fails!,
as Readle said just flash red_erom file and phone will be alive again,
if after red_erom not powering just reflash main+fs and solved,
best regards
Invisible
Old 05-23-2005, 16:12   #4 (permalink)
cavite_devil's Avatar
Member: 47271
Thanks Meter: 25
Post The Result If Working
c2r2
Old 05-23-2005, 16:31   #5 (permalink)
Invisible's Avatar
Member: 3956
Thanks Meter: 55
hi
tested 100%, I flashed a lot of v800 to z800 and np making anything you want with them
best regards
Invisible
Old 05-24-2005, 14:39   #6 (permalink)
Member: 47271
Thanks Meter: 25
Ok Tnx For the Feed Back
c2r2
How To Repair my V800??? taha2000 Sony Ericsson Hardware Repair 0 06-08-2007 14:19
Mainboard can you solve my V800 problem its pending since 7months sDinesh Cruiser Suite 9 12-25-2006 01:08
usb kill my v800 jln310 SonyEricsson (USB-Smart) 10 11-13-2005 14:19
why with my v800 GIGOLO Cruiser Suite 1 04-20-2005 22:49
Have I killed my 8210?? NJ Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 08-03-2001 01:42
Page generated in 0.33888 seconds with 8 queries
