07-03-2010, 17:53 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 03 Jul 2010: Huawei, Philips, Vodafone, Spice, Skyzen, MyPhone, Karbonn models... .Huawei-G3501 model supported .Karbonn-K451 model supported .MyPhone-Q22-Duo model under test .Philips-X620 model supported .Philips-X830 model supported .Skyzen-EZ1000 model supported .Spice-M3636 model supported .Vodafone-543 model under test .Motorola-WX288 operations improved .firmware database updated .models list updated .pinout database updated Infinity-Box 5 (five) years non-stop free updates and support: Infinity-Box - News - CDMA-Tool (fast and easy unlock) - Automatic pinout detection device - Language & Resource Editor for MT62xx based models - Extract phonebook (and other content) from alive and dead phone - Follow us on Twitter |
The Following 17 Users Say Thank You to YellowBoss For This Useful Post: |
07-04-2010, 14:45 | #11 (permalink) |
Junior Member Join Date: Jan 2008
Member: 693406 Status: Offline Thanks Meter: 0 | good, the problem I have the huawei com g6610 is that apparently makes perfect l unlock operation but nothing remains closed as the bands provide several forms and not leave anything you posting the log here LOG ==== [01/07/2010 16:16:21] ==== COM4 [VCP0] selected modulo v3.46 Servicio: Huawei-G6610 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:A203:0001 status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash EC227E22632260:0AEA0000000000 Flash AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.46, database date: 20.06.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610V_SS _G06_P63_M21_01_13.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610V_SS _G06_P63_M21_01_13.BIN project-id: G6610V.SS.G06.P63.M21.01.13, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... leyendo Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G66 10V_SS_G06_P63_M21_01_13__ffs... Archivo guardado: D:\Archivos de programa\InfinityBox\MModule\Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G66 10V_SS_G06_P63_M21_01_13__ffs_20100701-161951.B0E.bin Flash EC227E22632260:0AEA0000000000 Backup de datos requeridos Done ====> Revisión de datos requeridos ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Revisión de datos requeridos Done ====> Operacion Especial ... detecting parameters to apply patch area 1... .................................................. .................................................. ............................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ..... required data found Flash EC227E22632260:0AEA0000000000 Flash EC227E22632260:0AEA0000000000 Escribir area 2 (pass 1) .................................................. .................................................. ....................... area 2 patch applied Ok Operacion Especial Done ====> Escribir ... Flash EC227E22632260:0AEA0000000000 Escribir ffs Escribir Done ====> Finalizado ... Finalizado Done Finalizado, tiempo usado: 6 min 22 sec Quite/coloque la bateria ahora ! ==== [01/07/2010 16:24:48] ==== COM4 [VCP0] selected modulo v3.46 Action: read unlock codes Metodo unlock: read codes Modelo: Huawei-G6610 Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:A203:0001 status: FF Connecting at 19200, wait... Deje de presionar el boton power ahora ! Telefono detectado, espere... Hardware: MT6225,E05 Dato: 2006.06.14 Version: 1.0 Version: G6610V.SS.G06.P63.M21.01.13 Version: TINNO25_08A_GEMINI_HW 80 byte(s) read imei: 35183504031381 coneccion Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finalizado, tiempo usado: 12 sec Quite/coloque la bateria ahora ! ==== [01/07/2010 16:25:24] ==== COM4 [VCP0] selected modulo v3.46 Action: "sp-unlock" Metodo unlock: smart fast Modelo: Huawei-G6610 Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! 19200 autodetect Iniciando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:A203:0001 status: FF Connecting at 19200, wait... Deje de presionar el boton power ahora ! Telefono detectado, espere... Hardware: MT6225,E05 Dato: 2006.06.14 Version: 1.0 Version: G6610V.SS.G06.P63.M21.01.13 Version: TINNO25_08A_GEMINI_HW 80 byte(s) read imei: 35183504031381 coneccion Ok 185 byte(s) read Leyendo datos... reading data #2... construcción de nuevos datos.. escribiendo datos... 173 byte(s) read Leyendo datos... 972 byte(s) read construcción de nuevos datos.. escribiendo datos... verifying... verificacion Ok Listo Finalizado, tiempo usado: 20 sec Quite/coloque la bateria ahora ! |
07-04-2010, 19:27 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @carmelillo please, follow this instruction: Code: ==================== New firmware detected (v.3.46, database date: 20.06.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610V_SS _G06_P63_M21_01_13.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Leer full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== |
FREE UNLOCK SIM CARD FOR 20 PHILIPS DIGA PHONES ON CELLNET | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-17-2011 18:10 |
I need a full flash 200000-300000 for 6150 v5.03 | Zulan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-11-2001 10:25 |
3390 v7.03 f_loader and partial flash needed | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-17-2001 19:05 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
