03-09-2010, 20:06 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 09 Mar 2010: Pantech-C180, C320 models supported .Pantech-C180 model supported .Pantech-C320 model supported .Alcatel customization area detection improved .Alcatel unlock/flash operations improved .new flash file format supported .firmware database updated Infinity-Box 5 (five) years non-stop free updates and support: Infinity-Box Follow us on Twitter: Infinity_Box (Infinity_Box) on Twitter Last edited by InfinityHelp; 06-27-2020 at 09:51. Reason: legacy links removed |
The Following 20 Users Say Thank You to YellowBoss For This Useful Post: |
03-09-2010, 23:42 | #8 (permalink) |
No Life Poster Join Date: Dec 2007 Location: FomTekLAB Mexico-United States
Member: 645603 Status: Offline Thanks Meter: 89 | the C180 its the same like alcatel ot800 and c701,i have other pantech from telcel C600 you can contact me if need something to unlock this phone,regard |
03-10-2010, 18:45 | #13 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | have this letters and numbers: QUALCOMM MSM6245 DB7799.0 H1729006 --------------------------- HYCOUEHOM F3P6SS0E 2MGL7913E2 This from pantech C600 telcel |
The Following User Says Thank You to djkiddrick For This Useful Post: |
03-10-2010, 22:39 | #14 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | Thanks to my Friend LAYNA who made that cable to test this phone.To unlock this phone need firts flash and than use Unlock Standard. COM4 [VCP2] selected module v3.24 Device: Pantech-C180 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:70FD:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: SIMC23_07A_PCB01_GPRS_MT6223_S00.C180_V01_01B05.BI N project-id: C180_V01.01B05, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Pantech-C180_SIMC23_07A_PCB01_GPRS_MT6223_S00.C180_V01_01B 05__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Pantech-C180_SIMC23_07A_PCB01_GPRS_MT6223_S00.C180_V01_01B 05__ffs_20100310-142929.B0E.bin flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 38 sec Remove/Install battery now ! |
21 Mar 2010: Alcatel-OT-505 model supported | YellowBoss | Infinity-Box | 18 | 04-12-2010 11:44 |
Infinity-Box: non-stop updates: Pantech-C180, C320 models supported | YellowBoss | Service Products News & Updates | 0 | 03-09-2010 20:09 |
04 Mar 2010: Doro-338gsm, 326gsm models supported | YellowBoss | Infinity-Box | 6 | 03-08-2010 02:09 |
09 Jan 2010: UTStarcom, Alcatel, Bess models supported | InfinitySupport | Infinity-Box | 51 | 01-23-2010 11:02 |
16 Mar 2007: Pantech PG-1200 model supported | InfinitySupport | Infinity-Box | 14 | 03-18-2007 17:21 |
