03-21-2011, 17:54 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | 0fa9:s_ft_download_chksum_mismatch set history- sometime power on process done format but still didnt power on then flash the set getting error here is the log Code: COM18 [VCP1] selected module v3.78 Device: Micromax-Q5 Checking data, wait... Action: write flash NAND write: Firmware Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_08_2010-01-09_En.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... converting data... done 0x01F07E00 bytes bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_MMX_05_08.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E521_MP_F1_IN_MMX_05.08 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_MMX_05_08.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_08.BIN project-id: E521_MP_F1_IN_MMX_05.08, 0556E59E code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... converting data... done 0x01F07E00 bytes bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_MMX_05_08.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... error: can not write flash: 0FA9:S_FT_DOWNLOAD_CHKSUM_MISMATCH error: last error: 0FA9:S_FT_DOWNLOAD_CHKSUM_MISMATCH Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_08__system_log_20110321-222010.B4X.bin Finished, time used: 41 min 56 sec Remove/Install battery now ! Regards avtar |
03-21-2011, 18:02 | #2 (permalink) |
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | format ffs is also not working COM18 [VCP1] selected module v3.78 Action: reset settings ("format ffs") Model: Micromax-Q5 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 19 sec Remove/Install battery now ! |
03-21-2011, 18:06 | #3 (permalink) |
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | format in complete mode here is logs COM18 [VCP1] selected module v3.78 Device: Micromax-Q5 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E521_MP_F1_IN_MMX_05.08 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... incorrect ext bootloader signature: 70C70080 bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_08.bin incorrect bootloader signature: 098000EA incorrect bootloader signature: 098000EA nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN project-id: E521_MP_F1_IN_MMX_05.08, 0556E51E code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 1 min 0 sec Remove/Install battery now ! |
03-21-2011, 22:21 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, DOWNLOAD_CHKSUM_MISMATCH means that software trying to write flash, but results not good. In most cases this means that phone hardware is damaged. It may be (partially) damaged or bad soldered flash chip or f.e. water inside etc. |
Can't write flash: 0FA9:S_FT_DOWNLOAD_CHKSUM_MISMATCH | JC_BY | Infinity-Box | 1 | 11-15-2010 10:00 |
