11-10-2007, 16:00 | #16 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Very fast and safe. |
11-11-2007, 15:58 | #19 (permalink) | |
No Life Poster Join Date: Apr 2004 Age: 43
Member: 61557 Status: Offline Thanks Meter: 130 | Quote:
Can you help me my friend i cannot connect my unit n73 china mobile, it looks exactly the same as original n73, but the board inside has no interface for flashing..can you help me how can i work with the software i'am having problem in detecting the unit and i have also problem in selecting the right cable..i already do your advise before I downloaded the cable pinout updates. i select the n73 music edition but ther is no pinout display..i asume to use the n73 with drawing 3tx 4rx 8gnd , but i still cannot connect the mobile, i have also n95 slide and i have also the same problem....please can you help me thanks in advance my friend more power to infinity... DaWizard | |
11-12-2007, 00:08 | #20 (permalink) | |
My friend i already download the update here is my screenshot in deed infinity is the best..may be i neglect something thats why i cannot connect my mobile n73-rm133 (its not original N73 its china phone) n KtechN8899 bluetooth i cannot connect it also same problem occur what seems to be my problem here my friend i use the pinout in the latest update here is it can you give me some advise my friend i realy need to fix this mobile..when i insert sim and power it on it reboot/restart in the settings is there someting wrong? BR, DaWizard | |
11-12-2007, 04:10 | #21 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Dear DaWizard, You have sekected correct COM port so don'rt worry about settings. Here is detailed instruction how to solve pinout problem: 1. try to swap Rx <-> Tx wires 2. read this: Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
11-13-2007, 00:58 | #24 (permalink) | |
My Dear i Already try this solution but it seems not working with me..but i will try again my friend just for the sake of knowing what it feels when i discover the solution..btw i have here the same problem the Bluetooth Ktech series N8899. i use the cable of n95 18pins PDA series but it has same pinout as wat is shown in the pinouts but i cannot connect the mobile also..please i'am very sorry i hope you understand me.. DaWizard | |
11-13-2007, 02:37 | #25 (permalink) | |
Member: 61557 Status: Offline Thanks Meter: 130 | Sucess N73 china phone flash repair Quote:
==== log opened: [11/8/2007 2:49:27 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.64 S/N: 2ED0:0104 error: Dongle firmware[0104] is out of date ! Download latest upgrade-client (DongleManager) from support area and upgrade dongle firmware. ==== log opened: [11/8/2007 3:00:34 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.64 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [11/8/2007 4:01:33 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.64 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! ==== log opened: [11/8/2007 5:04:51 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.64 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! Device: Autodetect 6228 NAND COM3 [Winachsf0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! Boot Fail Finished, time used: 3 sec Remove/Install battery now ! Device: Autodetect 6205-6227 NOR COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! Boot Fail Finished, time used: 3 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? operation aborted COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! ==== log opened: [11/9/2007 4:45:40 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.64 S/N: 2ED0:010C Wait... ==== log opened: [11/9/2007 5:28:27 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.64 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [11/9/2007 5:29:24 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.64 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! ==== log opened: [11/9/2007 3:16:03 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! ==== log opened: [11/9/2007 3:24:49 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... ==== log opened: [11/9/2007 3:25:32 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [11/10/2007 3:25:38 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [11/10/2007 3:32:55 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Device: Autodetect 6228 NAND Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 11 sec Power off phone now ! Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! COM12 ready Action: imei Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 36 sec Power off phone now ! Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 75 sec Power off phone now ! Device: Autodetect 6205-6227 NOR COM3 ready Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... COM3 [Winachsf0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom serious damaged, use repair eeprom files or use other unlock/format method Operation failed ! Finished, time used: 12 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! COM3 [Winachsf0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! ==== log opened: [11/10/2007 3:44:39 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 11 sec Power off phone now ! Device: Autodetect 6228 NAND Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 11 sec Power off phone now ! Device: Autodetect 6205-6227 NOR Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Device: Autodetect 6228 NAND ==== log opened: [11/10/2007 3:52:05 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 12 sec Power off phone now ! Device: Autodetect 6228 NAND COM12 ready COM12 ready Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 76 sec Power off phone now ! Device: Autodetect 6205-6227 NOR Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 75 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 15 sec Power off phone now ! Device: Autodetect 6228 NAND Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 22 sec Power off phone now ! Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 14 sec Power off phone now ! Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 18 sec Power off phone now ! Device: Autodetect 6205-6227 NOR Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 64 sec Power off phone now ! ==== log opened: [11/11/2007 10:18:51 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done COM12 ready COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 18 sec Remove/Install battery now ! ==== log opened: [11/11/2007 10:29:04 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [11/11/2007 10:34:11 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 76 sec Power off phone now ! Device: Autodetect 6228 NAND Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 112 sec Power off phone now ! Device: Autodetect 6205-6227 NOR Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 19 sec Power off phone now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 3 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 207 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 79 sec Power off phone now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! Boot Fail Finished, time used: 19 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 27 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 351 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 15 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 47 sec Remove/Install battery now ! Loading file v.02... CM_KTech-N8899_E553_Y7AFTTDBT_E553_GPRS_MT6226_S01.K789+_02 _1_16m_En_Fr_Tr_Ar_Th.B0M.bin loaded protocol ver: 04 ver. sw1: E553_Y7AFTTDBT_E553_GPRS_MT6226_S01.K789+_02_1.BIN ver. sw2: K789+.E553_Y7AFTTDBT.02.1 Download manual from support area: Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm Languages: En Fr Th Tr Ar COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 141 sec Remove/Install battery now ! COM12 ready COM12 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: boot initialization step-3 failed: FF error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 30 sec Remove/Install battery now ! COM12 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 37 sec Remove/Install battery now ! Device: Autodetect 6228 NAND Loading file v.02... CM_KTech-N8899_E553_Y6ARTF_E553_GPRS_MT6226_S01.01_1_16m_En _Fr_Ru_Th_Ar.B0M.bin loaded protocol ver: 04 ver. sw1: E553_Y6ARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_Y6ARTF.01.1 Download manual from support area: Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm Languages: En Ru Fr Th Ar COM12 selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom warning: incorrect bootloader header error: unknown source file structure COM12 selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom warning: incorrect bootloader header error: unknown source file structure Device: Autodetect 6205-6227 NOR COM12 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom error: no data for Firmware Loading file v.02... CM_KTech-N8899_E553_Y7AFTTDBT_E553_GPRS_MT6226_S01.K789+_02 _1_16m_En_Fr_Tr_Ar_Th.B0M.bin loaded protocol ver: 04 ver. sw1: E553_Y7AFTTDBT_E553_GPRS_MT6226_S01.K789+_02_1.BIN ver. sw2: K789+.E553_Y7AFTTDBT.02.1 Download manual from support area: Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm Languages: En Fr Th Tr Ar COM12 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active error: boot initialization step-2 failed: error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 326 sec Remove/Install battery now ! COM3 [Winachsf0] selected ==== log opened: [11/11/2007 11:11:42 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 error: Dongle not connected ==== log opened: [11/11/2007 11:12:10 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done COM12 ready COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 80 sec Remove/Install battery now ! ==== log opened: [11/11/2007 11:19:47 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: boot initialization step-2 failed: error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 63 sec Remove/Install battery now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 85 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 79 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 28 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 75 sec Power off phone now ! Device: Autodetect 6228 NAND Action: read information Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 76 sec Power off phone now ! Device: Autodetect 6205-6227 NOR Device: Autodetect 6228 NAND COM12 selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! Boot Fail Finished, time used: 697 sec Remove/Install battery now ! COM12 ready Device: Autodetect 6205-6227 NOR Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 78 sec Power off phone now ! ==== log opened: [11/11/2007 12:15:35 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 78 sec Power off phone now ! COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: boot initialization step-2 failed: error: boot initialization step-3 failed: error: boot initialization step-2 failed: error: boot initialization step-3 failed: error: boot initialization step-2 failed: error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 711 sec Remove/Install battery now ! ==== log opened: [11/11/2007 1:44:51 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 52 sec Power off phone now ! ==== log opened: [11/11/2007 1:46:47 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 62 sec Power off phone now ! ==== log opened: [11/11/2007 2:42:43 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 81 sec Power off phone now ! COM1 ready Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 63 sec Power off phone now ! ==== log opened: [11/11/2007 4:19:00 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 78 sec Power off phone now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 78 sec Power off phone now ! ==== log opened: [11/12/2007 4:28:17 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! Operation failed ! Finished, time used: 76 sec Power off phone now ! COM1 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 23 sec Remove/Install battery now ! COM1 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 69 sec Remove/Install battery now ! COM1 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 38 sec Remove/Install battery now ! COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 58 sec Remove/Install battery now ! ==== log opened: [11/12/2007 4:37:36 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.65 S/N: 2ED0:010C Wait... Device: Autodetect 6205-6227 NOR Done COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 97 sec Remove/Install battery now ! COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.0CBB62C9.[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN_E7AD9F52].rpl identification detection finished device-id: 0CBB62C9 protocol ver: 04 ver. sw1: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN ver. sw2: V2.0628.0.0.1 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [flash[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\Save\N73 Music Ed\backup_flash[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN]_20071112-171015.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\Save\N73 Music Ed\backup_system_log_0CBB62C9_SZMI26_05C_SET_PCB01 _GPRS_MT6226_S01.V2_0628_0_0_1.BIN_E7AD9F52_200711 12-171105.B0X.bin Finished, time used: 1845 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: Nokia N73(11) Software version: V2.0628.0.0.1" Software date: 2005.04.12 Barcode: 0615016537 10 imei: 135790246811220 Finished, time used: 19 sec Power off phone now ! COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.0CBB62C9.[SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN_E7AD9F52].rpl identification detection finished device-id: 0CBB62C9 protocol ver: 04 ver. sw1: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN ver. sw2: V2.0628.0.0.1 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete eeprom element #1 detected ok file saved: C:\Program Files\InfinityBox\ChineseMiracle\Save\N73 Music Ed\backup_system_log_0CBB62C9_SZMI26_05C_SET_PCB01 _GPRS_MT6226_S01.V2_0628_0_0_1.BIN_E7AD9F52_200711 12-171504.B0X.bin Finished, time used: 126 sec Remove/Install battery now ! Loading file v.02... CM_Nokia-N73-Music-Edition_SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_06 28_0_0_1_16m_Ru_Fr_En_Th_Vn_Cn_Hi_Cn_Ar.B0M.bin loaded protocol ver: 04 ver. sw1: SZMI26_05C_SET_PCB01_GPRS_MT6226_S01.V2_0628_0_0_1 .BIN ver. sw2: V2.0628.0.0.1 Languages: En Ru Fr Th Vn Cn Ar WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... COM1 selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... Connecting, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can't finalize test moide Operation failed ! Finished, time used: 20 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... COM1 selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... Connecting, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can't finalize test moide Operation failed ! Finished, time used: 20 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... COM1 selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... Connecting, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can't finalize test moide Operation failed ! Finished, time used: 19 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... COM1 selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: V2.0628.0.0.1 Version: NokiaN73(11) detecting structure #2... done imei: 13579024681122 connection Ok building list... done items to clear: 227 163 of 227 items cleared 0 items remains Finished, time used: 413 sec Remove/Install battery now ! At last for a very long time i have succesfully create my own cable and succesfully flash the n73 china mobile..it's worth trying .... Thanks Infinity for your support hope you release a new updates this coming months..Congratulations to my self for a job well done!!!!!!!!!! BR, DaWizard | |
30 Nov 2007: "Pinouts" v1.21 released | InfinitySupport | Infinity-Box | 24 | 12-06-2007 16:02 |
10 Nov 2007: "ChineseMiracle" v1.65 released | InfinitySupport | Infinity-Box | 21 | 11-15-2007 10:40 |
02 Oct 2007: "Pinouts" v1.16 released | InfinitySupport | Infinity-Box | 13 | 10-03-2007 18:34 |
23 Sep 2007: "Pinouts" v1.15 released | InfinitySupport | Infinity-Box | 11 | 09-24-2007 08:37 |
07 Jul 2007: "Pinouts" v1.08 released | InfinitySupport | Infinity-Box | 9 | 07-12-2007 21:51 |
