Old 01-11-2010, 19:46   #1 (permalink)
Member: 130995
Thanks Meter: 35,227
11 Jan 2010: Vodafone, Huawei, Zonda, Bird models
"MModule" v3.02 released:
.Vodafone-135 model under test
.Huawei-G5010 model under test
.Huawei-G6610 model under test
.Huawei-G7002 model under test
.Zonda-1098 model supported
.Bird-K298a model supported
.Nexian-NX-G922 model under test
.Alcatel operations improved (new firmware types supported)
.firmware database updated
ATTENTION: always make full flash backup before any operation for models that is "under test"
Please, post here your test reports so we will be able to see results and fix any possible bugs.
The Following 61 Users Say Thank You to InfinitySupport For This Useful Post:
Old 01-12-2010, 11:08   #2 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Hello, ...
Trying to reset phonelock but not success ...
here is log :
Using standart methode
COM7 [VCP0] selected
module v3.02
Device: Nexian-NX-G922
Checking data, wait...
Action: "user code"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:8D03:0001
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 1C007C001C007C:1C007C00000000
flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1.BIN
project-id: E502-3B.MP.RS.ID.TELKOMSEL.V1, 00000000
code offset: 00000000
ffs offset/size [01]: 01000000/00FE0000
TCL-ID is absent
ffs/eeprom address assigned: 01000000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Nexian-NX-G922_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs...
file saved: D:\Program Files\InfinityBox\MModule\Nexian-NX-G922_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs_20100112-164455.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 17 min 46 sec
Remove/Install battery now !
Another methode still no luck ...
thanks
The Following 2 Users Say Thank You to Edocomsel For This Useful Post:
Old 01-12-2010, 17:46   #3 (permalink)
Member: 416710
Thanks Meter: 391
Huawey G5010 log here
COM6 [VCP0] selected
module v3.02
Action: "sp-unlock"
unlock method: smart fast
Model: Huawei-G5010
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:ADC6:000C
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: A1.1VZ01V01.12
Version: BYD23C_08B_PMWY_HW
80 byte(s) read
imei: 01211500027548
connection Ok
185 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
173 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 12 sec
The Following 3 Users Say Thank You to Celhack For This Useful Post:
Old 01-12-2010, 18:20   #4 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
nice team work .. thanks for this
The Following User Says Thank You to MYUNLOCKING For This Useful Post:
Old 01-12-2010, 20:10   #5 (permalink)
jesedavidfrv's Avatar
Member: 914317
Sonork: 100.1601159
Thanks Meter: 66
g5010 movistar colombia
modulo v3.02
Action: "sp-unlock"
Metodo unlock: smart fast
Modelo: Huawei-G5010
Checkeando datos, espere...
El Telefono deberia estar APAGADO !
Mantenga Presionado el boton Power !
19200 autodetect
Iniciando [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:AE05:000C
status: FF
Deje de presionar el boton power ahora !
Telefono detectado, espere...
Dato: 2000.00.00
Version: 1.0
Version: A1.1CQ01V01.04
80 byte(s) read
imei: 01211500001314
coneccion Ok
185 byte(s) read
Leyendo datos...
construcción de nuevos datos..
escribiendo datos...
173 byte(s) read
Leyendo datos...
972 byte(s) read
verifying...
verificacion Ok
Listo
Finalizado, tiempo usado: 13 sec
Quite/coloque la bateria ahora !
The Following 5 Users Say Thank You to jesedavidfrv For This Useful Post:
Old 01-12-2010, 21:54   #6 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
everyone wants new ZONG and UFONE phones to full supported
The Following 3 Users Say Thank You to makkah mobile For This Useful Post:
Old 01-12-2010, 22:13   #7 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
I am testing unlock huawei G6610 movistar colombia, but i can´t do it, get error.
Show the Log.
COM3 [VCP0] selected
modulo v3.02
Action: "sp-unlock"
Modelo: Huawei-G6610
19200 autodetect
Iniciando [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:0503:0007
status: FF
Peligro: wrong packet cs
Peligro: can't read software version, probably unknown firmware
80 byte(s) read
connección perdida
error: La operación falló !
Finalizado, tiempo usado: 7 sec
i already made Read eeprom, Fullflash and FFS complete and was perfect, but unlock get error.
The Following 2 Users Say Thank You to Hacker84 For This Useful Post:
Old 01-12-2010, 23:23   #8 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Huawei G6610 Repair imei Good.
Action: "repair imei"
El telefono deberia estar Encendido !
Conectando, espere...
imei-1: 358688------232
Metodo de escritura de imei: modo-1
Canal de escritura de imei: imei #1 para dual sim/mono CPU
new imei-1: 012122001234567
verificacion Ok
Finalizado, tiempo usado: 2 sec
The Following 4 Users Say Thank You to Hacker84 For This Useful Post:
Old 01-13-2010, 01:51   #9 (permalink)
Member: 130995
@Edocomsel
please, try to make "read unlock codes".
What is the results ?
Old 01-13-2010, 01:53   #10 (permalink)
Member: 130995
modulo v3.02
Action: "sp-unlock"
19200 autodetect
CPU: MT6223
status: FF
Dato: 2000.00.00
Version: 1.0
80 byte(s) read
coneccion Ok
185 byte(s) read
Leyendo datos...
173 byte(s) read
Leyendo datos...
972 byte(s) read
verifying...
verificacion Ok
Listo
please, read full flash from this phone and send full flash backup file (or link) to [email protected]
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 01-13-2010, 04:39   #11 (permalink)
maomatrix's Avatar
Member: 901711
Sonork: 100.1606138
Thanks Meter: 427
Which cable use for UNLOCK HUAWEI G5010.....???? or use PIN FINDER for discovery..?????
Old 01-13-2010, 05:06   #12 (permalink)
Member: 42165
Thanks Meter: 35
sir may I ask with this update..is it already supported the New security for alcatel phones Like s211 and the like?
nice update nice to see the team is giving effort to support their customers for several years..
Old 01-13-2010, 05:36   #13 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
nice update but need huwei t156 new security and zong a316g+ unlock.
Old 01-13-2010, 05:38   #14 (permalink)
gsmstyle_1's Avatar
Member: 449617
Thanks Meter: 1,034
Nice update................
But what About .Huawei T156 (U Fone)
We Wait
The Following 7 Users Say Thank You to gsmstyle_1 For This Useful Post:
Old 01-13-2010, 06:00   #15 (permalink)
.::kabir::.'s Avatar
Member: 638416
Sonork: 100.1591787
Thanks Meter: 1,113
graet updete thenks infinity ,,,,,,,,,,,,,,,,,,,,,
09 Jan 2010: UTStarcom, Alcatel, Bess models supported InfinitySupport Infinity-Box 51 01-23-2010 11:02
vodafone huawei zonda and bird up date naveedbutt Infinity-Box 0 01-13-2010 05:03
Infinity-Box: Vodafone, Huawei, Zonda, Bird models InfinitySupport Service Products News & Updates 0 01-13-2010 02:44
UPDATE 11 JAN 2006: Bird S299 model added InfinitySupport Infinity-Box 40 05-06-2009 19:26
22 Jan 2009: WORLD 1st: Fly, Bird, Vodafone, Bleu, Alcatel models supported InfinitySupport Infinity-Box 46 02-16-2009 16:47
Page generated in 0.28467 seconds with 10 queries
