09-10-2008, 09:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Moto W375 Unlock Problem i've one W375 i'm not able to unlock it here is the log. Code: Application: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.48 S/N: xxxxxxxxxxxxx Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: W375 COM5 [VCP0] selected Action: unlock W375 unlock is under test ! Recommended action before unlock: make eeprom backup Do you want to continue without backup ? operation terminated Finished, time used: 6 sec Remove/Install battery now ! COM5 [VCP0] selected Action: read eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... error: incorrect certificate Release Power button ! Connect Fail Finished, time used: 12 sec Remove/Install battery now ! COM5 [VCP0] selected Action: unlock W375 unlock is under test ! Recommended action before unlock: make eeprom backup Do you want to continue without backup ? Flex file must be loaded before unlock operation. Please refer to unlock instruction/manual for more details ! Do you want to continue and load Flex file now ? trying to load Flex file... error: required Flex file not loaded, operation aborted. Finished, time used: 8 sec Remove/Install battery now ! COM5 [VCP0] selected Action: read information Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... error: incorrect certificate Release Power button ! Connect Fail Finished, time used: 12 sec Remove/Install battery now ! COM5 [VCP0] selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... error: incorrect certificate Release Power button ! Connect Fail Finished, time used: 19 sec Remove/Install battery now ! COM5 [VCP0] selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... error: incorrect certificate Release Power button ! Connect Fail Finished, time used: 10 sec Remove/Install battery now ! COM5 [VCP0] selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... error: incorrect certificate Release Power button ! Connect Fail Finished, time used: 10 sec Remove/Install battery now ! i try all certificate methods. Take Care ENJOY |
09-10-2008, 13:15 | #4 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote: Take Care ENJOY | |
09-10-2008, 20:37 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | Quote:
GOOD LUCK | |
09-11-2008, 01:03 | #7 (permalink) | |
i did try the both options u mentioned but doesn't help i think this fone can't b unlocked right now as the InfinitySupport Mentioned that they are working on this direction. Take Care ENJOY | |
10-21-2008, 09:36 | #9 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 470646 Status: Offline Thanks Meter: 58 | motorola w375 dead after flash in infinity here log. COM8 [VCP0] selected "smart write" active Action: flash Write: Firmware Skip: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.0.71 HW version: MOTOROLA_H80S LP ver: 0071_A04 Flex ver: FLEX_A0_00H cpu id: 08B6 imei eeprom: 3558420108280208 required SW version: 0.0.71 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35584201082802_20081021-131926.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Flex Write Done Finished, time used: 442 sec Remove/Install battery now ! |
Moto w375 keypad problem | waqarN70 | Motorola Hardware Repair | 2 | 06-17-2009 10:34 |
Moto W375 Unlocked | thushdt | Infinity-Box | 1 | 01-14-2009 10:06 |
w375 unlock problem | troo | Smart-Clip | 19 | 01-05-2009 09:34 |
w375 unlock problem | troo | Infinity-Box | 1 | 11-26-2008 19:41 |
W375 unlock problem,,,,sending boot,,,,failed | steca | Smart-Clip | 14 | 05-26-2007 12:39 |
