08-11-2008, 12:50 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | 1110i China Bad Software Solve??? COM5 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:78C8:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: N1112_V5.53 Version: detecting structure #2... 0 done 44 byte(s) read imei: 35935300284129 connection Ok building list... done items to clear: 118 118 of 118 items cleared building list... done 0 items remains Finished, time used: 431 sec Remove/Install battery now ! |
08-11-2008, 13:12 | #2 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Waiting for update ...At the moment infinity box and other not support for repair badsoft like (1110i,5310....) 1110i write backup from a good phone but the same tested many times. TGT Maybe ? |
The Following User Says Thank You to Star75 For This Useful Post: |
08-11-2008, 23:20 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello, Here is latest Infinity-Box "Chinese Miracle" software with "repair bad software" function: http://www.infinity-box.com/download...acle_v2.56.rar It's first release and it was tested for limited number of phones, so please, try to use it and let us know about results. Many thanks to respected Mr. Noman, Mr. Chandreshswami and many other friends who helps us with phone samples, tests and advices ! |
08-12-2008, 05:54 | #6 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
sucess bad software problam hear is tha log Code: COM17 [VCP0] selected Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:9E03:000A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M608_V_1.22SERV_P1HxM25BC30_INTEL_MULTI Version: Mobileden25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is wrong ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #6 (mode-1)... done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 11 sec Remove/Install battery now ! Great work for Infinity team Thank you | |
The Following 2 Users Say Thank You to .::AZEEM::. For This Useful Post: |
08-12-2008, 05:58 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. Please, if you can, read flash from your phone and send it to [email protected] so we will be able to upload more files in support area. |
08-12-2008, 06:45 | #8 (permalink) |
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | Try to repair bad software but not solve here is log. COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:78C8:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53.BIN ver. sw2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... ................................ done firmware protection firmware structure #8 is not found Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25062501:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... Finalization Done Finished, time used: 24 sec Remove/Install battery now ! Here software ask (first step compleat 1 of 2 now press ok for second step) but have error for step 2 COM5 [VCP0] selected Action: repair "bad software" error: repeat operation ! error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! what should i do. |
08-12-2008, 06:47 | #9 (permalink) | |
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | 5310 Repair Bad software ok but phone no network thank infinity team Quote:
08-12-2008, 09:56 | #12 (permalink) |
Freak Poster Join Date: Sep 2007 Location: KERALA,INDIA Age: 38
Member: 597241 Status: Offline Sonork: 100.1575009 Thanks Meter: 85 | infinty v2.56 repaired badsoftware successfully -------------------------------------------------------------------------------- model :jinpeng v9188 Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.56 S/N: ***x:***x Wait... Device: Autodetect 6205-6227 NOR Done COM38 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:7003:000A boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SINGLE25_06B_PCB01_GPRS_MT6225_S00.J800_V1_00.BIN ver. sw2: J800_V1.00, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... ............................................ done detecting firmware structure #9... .................................................. ... done detecting firmware protection failed Finished, time used: 47 sec Remove/Install battery now ! COM38 [VCP0] selected Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:7003:000A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: J800_V1.00 Version: Single25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is wrong ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #6 (mode-1)... done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! heres the log THANKS INFINITY UR THE KING OF CHINESE PHONES |
The Following User Says Thank You to vijeeshkannur For This Useful Post: |
08-12-2008, 10:31 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello guys! for all who have problems with repeairing bad software i would advice to start from flashing. flashing +format ffs+ repair bad software this must be sequence of operations here is 1112 flash file: flashfiles/ChineseMiracle/_MT6225/TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53_Nokia-1112_8Mb_En_Fr_Vn_Ru_Ar_Persian_Th.B0M.bin |
08-25-2008, 17:39 | #15 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: NABINAGAR
Member: 747297 Status: Offline Sonork: [email protected] Thanks Meter: 47 | Infinity-Box UP TO DATE FOR RIAZ_NET : Quote:
1200 china bad software | 8sme | Chinese Models & Cloned Phones | 7 | 07-08-2009 14:42 |
1112 China Bad Software ????????? | dil_PAKISTANI | Infinity-Box | 7 | 02-28-2009 23:06 |
1112 China Bad Software After Format........ | dil_PAKISTANI | Infinity-Box | 1 | 01-03-2009 15:19 |
Bad Software Solved By 2.56 | cellbhai | Infinity-Box | 2 | 08-14-2008 22:03 |
5310 nokia china bad software | ahmertelecom | Infinity-Box | 13 | 08-11-2008 23:17 |
