02-12-2011, 19:44 | #31 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Bogotá Colombia Age: 43
Member: 150844 Status: Offline Thanks Meter: 309 | Now whit new version read codes: Code: COM6 [VCP0] selected module v3.74 Action: read unlock codes unlock method: read codes Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC13B156 Version: VER.A 80 byte(s) read imei: 86334900044376 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: - 12345678 lock[2] code: - 56781234 lock[3] code: - 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: - 7788 lock[7] code: - 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 20 sec Remove/Install battery now ! Then unlock smart fast: Code: COM6 [VCP0] selected module v3.74 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC13B156 Version: VER.A 80 byte(s) read imei: 86334900044376 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! Whitout sim or whit testsim work (can enter to menu). After format ffs power again whit software error 23 whit sim, w/out can see menu. Firmware are same as movistar from support because im flash but cant solve software error, original are from movilnet Venezuela, but i dont have backup. |
02-12-2011, 20:16 | #32 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, try to repair imei, I think that imei that I can see in log (86...) is not the same as at phone back label. What is situation after imei repair ? |
02-12-2011, 20:27 | #33 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239508 Status: Offline Thanks Meter: 6 | i am send the link for [email protected] On 10 January 2011 12:16 http://rapidshare.com/files/441355425/SFR-151.B0M.bin you want read the full flash after unlock and send for you |
The Following User Says Thank You to newman201 For This Useful Post: |
02-12-2011, 20:31 | #34 (permalink) |
Member: 239508 Status: Offline Thanks Meter: 6 | but this the unlock method : read codes not work just with smart fast sp-unlock unlock methode read codes COM13 [VCP0] selected module v3.74 Action: read unlock codes unlock method: read codes Model: SFR-151 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [****:8A05:****]... CPU: MT6223 chip: 0011:6994:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: Z525.C136.HW3.SW2.V7.05 Version: YUANDA23C_09A_HW 86 byte(s) read imei: 3535780******0 connection Ok 193 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 181 byte(s) read reading data... 188 byte(s) read lock[1] code: + 13268590 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 14 sec Remove/Install battery now ! |
02-12-2011, 21:42 | #35 (permalink) | |
Member: 150844 Status: Offline Thanks Meter: 309 | Quote:
After flash whit this Mmodule 3.74 cant power on, only blink and restart (whit or w/out sim), but after flash whit 3.73 come back to life but software 23 error as always. | |
02-13-2011, 14:37 | #40 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | who have unlocked huawei g3610? by read codes all codes not accepted, by smart fast unlock not unlocked by standart unlock phone dead |
02-13-2011, 17:44 | #41 (permalink) |
Freak Poster Join Date: Jan 2007 Location: india
Member: 431754 Status: Offline Thanks Meter: 30 | Any way Thanks to infinity teem-MModule update From Long time Only MModule & MModule update PinFinder 1.24 already installed Language 1.10 already installed MModule 3.75 already installed Informer 1.02 already installed LgA 1.39 already installed BModule 1.33 already installed Pinout 1.52 already installed ChineseMiracle 3.26 already installed HModule 1.38 already installed Pinout 1.52 already installed QCModule2 1.14 already installed Pana01 1.78 already installed http://forum.gsmhosting.com/vbb/f425...nager-1206927/ thanks |
02-14-2011, 06:24 | #42 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | I unlock ZTE S 213 is ok but not unlock after unlock my phone have porblem the same old version 3.73 COM46 [VCP0] selected module v3.75 Device: ZTE-S213 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:75A9:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 208848FFFFFFFF:20884800000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.75, database date: 12.02.2011): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_2B02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_2B02.BIN project-id: KE-KP-BE9D-P109A14V1.0.2B02, 00000000 code offset: 00000000 ffs offset/size [02]: 006F0000/00110000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 006F0000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_2B02__ffs... file saved: C:\Program Files\InfinityBox\MModule\11ZTE-S213_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_2B02__ffs_20110213-174054.B0E.bin flash: 208848FFFFFFFF:20884800000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ......................... required data found flash: 208848FFFFFFFF:20884800000000 flash: 208848FFFFFFFF:20884800000000 Write: area 1 (pass 1) ....... area 1 patch applied Ok detecting parameters to apply patch area 2... ............... required data found flash: 208848FFFFFFFF:20884800000000 flash: 208848FFFFFFFF:20884800000000 Write: area 2 (pass 1) ................. area 2 patch applied Ok Special operation Done ====> Write ... flash: 208848FFFFFFFF:20884800000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 10 sec Remove/Install battery now ! Pls help me. thanks. |
02-14-2011, 09:36 | #43 (permalink) | |
Code: ==================== New firmware found (v.3.75, database date: 12.02.2011): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.KE-KP-BE9D-P109A14V1_0_2B02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== | |
02-14-2011, 13:33 | #44 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Sarajevo,Bosnia
Member: 97044 Status: Offline Thanks Meter: 41 | Huawei- G7007 All this CODE are WRONG Here Log COM3 [VCP0] selected module v3.75 Action: read unlock codes unlock method: read codes Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC68B148 Version: VER.A 80 byte(s) read imei: 35xxxxxxxxx connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 12345678 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to Salkovic For This Useful Post: |
02-14-2011, 14:42 | #45 (permalink) |
Major Poster Join Date: Sep 2006 Location: Bulgaria Age: 44
Member: 355697 Status: Offline Thanks Meter: 4 | I have the same problem with Huawei G7007. After I change the firmware I got error 23...help me COM4 [VCP0] selected module v3.75 Action: "repair imei" imei write method: mode-2 new imei: 357xxxxxxx Model: Huawei-G7007 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC46B182 Version: VER.B 80 byte(s) read imei: 357xxxxxxxxx connection Ok 80 byte(s) read verification... verification done: 357xxxxxxxx Finished, time used: 12 sec Remove/Install battery now ! |
Nokia6150 V 4.613 NSM-1 16-12-98 | sjakie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-23-2017 22:11 |
unlocking nokia 5110 version5.12 5.20 | tomi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 02-25-2011 10:16 |
how to unlock a 6150 with v5.02 | stefan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 01-29-2001 11:11 |
Nokia 6150 5.02 Stupid Security Code!!! | Ringnet | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-04-2000 01:27 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
