12-28-2007, 15:43 | #1 (permalink) |
No Life Poster Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | regarding CECT u90 i m confused coz my set wasnt ok. |
12-28-2007, 15:48 | #2 (permalink) |
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | heres the flashing log of the flashing from file which was readed. COM20 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs source data: page+spare converting data... done 0x07C1F800 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1 ffs offset/size: 02000000/06000000 id-page Ok warning: probably incorrect/unknown source file warning: probably incorrect/unknown source file warning: ffs size mismatch: 05C1F800/06000000 nfi area detection finished: Ok Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 460800 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN_D2629EBF].rpl New firmware detected: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished security area#1 backup loaded security area#1 calculation... Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _27EADFDB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_32 0_7670_HYN_HY128_V2_1.BIN_D2629EBF_20071228-204727.B4X.bin write core area 1 of 3... write core area 2 of 3... error: code: 00000BF4 error: code: FF070000 error: block/offset: 00000BE9/00BE9000 error: can't write nand core Write Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _27EADFDB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_32 0_7670_HYN_HY128_V2_1.BIN_D2629EBF_20071228-205519.B4X.bin Finished, time used: 548 sec Remove/Install battery now ! |
12-28-2007, 15:49 | #3 (permalink) |
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | and log of format COM20 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 460800 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation error: unexpected answer: error: unexpected answer: security area#1 damaged, recalculation required identification#1 detection finished Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done Finished, time used: 58 sec Remove/Install battery now ! |
12-29-2007, 17:50 | #5 (permalink) | |
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | my set turns off immedeatly after power on. just shows me the progress bar then shut down. now its dead after many try's. i have formate succesfully but no luck. and what dose it mean???? Quote:
dead cect u90 revived with infinity | aliakbar | Infinity-Box | 8 | 06-01-2009 16:23 |
cect u90 tv mobile | kasim | Infinity-Box | 3 | 06-23-2008 13:43 |
Cect U90 tv | Kent İletişim | Infinity-Box | 8 | 01-20-2008 21:15 |
pin out cect u90 18pin? | taleb_nazari | Infinity-Box | 3 | 11-07-2007 11:24 |
