Old 01-30-2016, 14:43   #1 (permalink)
johnmadzeka1's Avatar
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 315
Question HUAWEI T1-701U Sp Unlock cant Connect
HUAWEI T1-701U SPD cant connect so that I can I unlock [CODEChinese Miracle II [SPD module] v 1.13
Operation : Check/Read Info [ v1.13 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 88 ]
Port Opened
Sync...
Initial Boot Failed!
Reconnect Power/Cable!][/CODE]
Tryed more than 3 phones
Need ur help thanx
Old 01-30-2016, 15:04   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
And will not connect. Check a little over search. All already explained.
Old 01-30-2016, 15:35   #3 (permalink)
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 315
Give me link sir thnx for your support
Old 01-30-2016, 15:40   #4 (permalink)
JayDi's Avatar
Member: 462970
Sure, can check all , what you need to know about this model here
Old 01-30-2016, 16:20   #5 (permalink)
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 315
I searched But couldn't find my Answer Regarding the Infinity Box I use, if u could just help me with No or Yes Supported with CM2 will be Happy
Old 01-30-2016, 16:23   #6 (permalink)
JayDi's Avatar
Member: 462970
If you can't find - then NO. Not supported.
Old 01-31-2016, 05:25   #7 (permalink)
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 315
Thumbs up Not Supported
I think i have gathered All info I need: http://forum.gsmhosting.com/vbb/f296..._701u-2041977/ You can CLOSE This thread
Old 02-11-2017, 12:10   #8 (permalink)
Member: 56090
Thanks Meter: 162
10:18:03 - Starting ADB Server..
10:18:09 - Manufacturer: HUAWEI
10:18:09 - Model: T1-701u
10:18:09 - Android Version: 4.4.2
10:18:09 - Build ID: T1-701uV100R001C199B005
10:18:09 - Board ID: sp7731gea_lm
10:18:09 - Chipset Platform: sc8830
10:18:09 - Checking Root access: True
Operation : Check/Read Info [ v1.24 ]
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 51 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_14B_TSHARK28_HUAWEI_PAD_W15.17_P1_Debug
Project : sc7731g_CP0_modem
HWInfo : sc7731g_CP0_modem
Compile : 04-21-2015 16:27:53
Phone Security Info :
IMEI [1] : 86693602xxxxxxxx (Huawei MedaiPad T1-701u have one imei)
IMEI [2] : 352751019523267
BT_ADDR : 000000000000
SelfInfo :
BatVoltage : 3.869 V
Done
Can only read info in service mode other functions no
Salam
Salam
The Following User Says Thank You to abdoune For This Useful Post:
Old 04-13-2017, 18:12   #9 (permalink)
Member: 220595
Thanks Meter: 355
so, can this model be unlocked or not ?
Old 04-19-2017, 19:41   #10 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
2. Insert cable
Phone found! [ 51 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
SelfInfo :
Done
Salam
Salam
Based on the info I have highlited from the post above unlock is not possible.
The Following User Says Thank You to y3kt For This Useful Post:
Old 07-01-2017, 15:41   #11 (permalink)
Member: 1349702
Page generated in 0.23254 seconds with 8 queries
