10-09-2008, 10:57 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: morocco
Member: 85019 Status: Offline Sonork: 100.1603419 Thanks Meter: 37 | ke820 dead i try to flash ke820 for change language and now phone become dead i try all flashfiles in suport and send eprom too and no result hang sometimes in white screen and powe off quily no eror during flash procedure i test too this one KE820P40-07-V10w-000-00_FEB-07-2007_file_system[1].B1S.bin w8 answer from suport |
10-09-2008, 11:48 | #2 (permalink) |
Member: 85019 Status: Offline Sonork: 100.1603419 Thanks Meter: 37 | here log file COM8 [VCP0] selected Device: LG-KE820 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta_20081009-112554.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta2_20081009-112557.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sec_35030526000000100_20081009-112600.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20081009-112601.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Writing: Eeprom Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 1005 sec |
10-09-2008, 12:49 | #3 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
regards notgood | |
10-09-2008, 13:07 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @KingOfGsm Please, check phone battery voltage, battery may be empty after flash process. Is it the same situation with all files from support (power-on with white screen) or situation is different with different flash files ? |
03-03-2009, 22:02 | #10 (permalink) |
Freak Poster Join Date: May 2006 Location: agadir oufla.
Member: 273511 Status: Offline Thanks Meter: 84 | i have the same issue with 2 lg ke820 : after flash tottaly dead or with blinking logo screen. hve tried all flash & eeprom repair files in support ,no way. i think i they are version m. i see the every time backup is with emei like this 35030526000000100. i maked a fuul flash backup but i tray to restor it soft said error data. so please infinitysupport can u tell what to do next. here is a log COM9 [VCP0] selected module v1.63 Device: LG-KE820 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static_20090302-152225.B1E.bin reading eeprom-static2... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static2_20090302-152226.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-security_35030526000000100_20090302-152228.B1E.bin reading eeprom-complete_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20090302-152229.B1E.bin backup critical area Done Check memory ... completed Finished, time used: 17 sec Remove/Install battery now ! OM9 [VCP0] selected module v1.63 Device: LG-KE820 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static_20090302-175450.B1E.bin reading eeprom-static2... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static2_20090302-175451.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-security_35030526000000100_20090302-175451.B1E.bin reading eeprom-complete_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20090302-175452.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, time used: 1017 sec Remove/Install battery now ! Last edited by jeanbrume; 03-03-2009 at 22:08. |
03-03-2009, 23:49 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Open phone Remove (desolder) small backup battery Wait 15 min Solder battery back |
Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
help!! ke820 dead after flash | biri26 | FuriousGold | 6 | 09-25-2009 23:10 |
Vygis need your help please KE820 TOTALY dead ! | jr90 | VygisToolbox | 1 | 11-24-2008 10:26 |
ke820 dead | KingOfGsm | VygisToolbox | 0 | 10-08-2008 21:35 |
Ke820 File Wanted | RRRRR | LG | 0 | 02-23-2007 08:54 |
