09-09-2005, 08:34 | #1 (permalink) |
Product Supporter Join Date: Apr 2001
Member: 4261 Status: Offline Thanks Meter: 22 | 2 x X70 death The first phone x70 when unlocking some error during unlocking and now phone can not power on... The second phone when we flash with Winmodo - during flashing stop to flash and now only phone light... Any idea how to repair these phones? I am ready to send phones to infinity team and pay small money to get all these two phone alive because all two customers are angree... Thanks for any answer. Mirek |
09-09-2005, 11:06 | #3 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | Quote:
why are u blaiming infinity team for that? i think their software is 100% ok , bcs i never fallen in any pb for unlock X70.for ur information i have unlocked around 35-40 X70 phones without any pb.so,its not infinity software's fault.so,i don't think so like you. proxy_gsm | |
09-09-2005, 18:56 | #4 (permalink) | |
Need to know more details. 1st phone: pls, tell me exactly what was the error. You can see unlock process progress in the Log_X70.txt file. Can you try to repeat unlock process ? 2nd: what was the error exactly ? Can you try to flash it again with winmodo ? Possible death reason for this phone: hardware problem. It can be that flash chip not so good. In other case flashing process have to be finished w/o any problems. As about first phone: can't say anything exactly until i'll see details from log file. | |
09-10-2005, 19:47 | #5 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
bcz therez no wrong with Infinity plz remember For Unlocking X70 u have to recharge its BATT 101% OK... otherwise forsure 202% u will kill ur X70. Now try to Flash it with Winmodo Step:-1 101% Fully Charged BATT. Step:-2 Backup of UPS (Very Very Important Stuff for this Field) 4. Start Winmodo 5. Menu Option -> Boot download: Checked 6. Menu Option -> Smart boot update: Checked 7. Menu Settings -> COM port: select COM port 8. Menu Settings -> Baud Rate: select 115200 9. "CUST" area: Red 10. "LP" area: Red 11. "CODE" area: Green 12. Press "Browse" button and select flash file 13. Connect cable to PC 14. Connect cable to phone 15. Press "Start Download" button 16. Shortly press phone power button if Menu Settings -> Baud Rate: select 115200 does not Workout then u can Reduce it... my Best Wishes r with u Try it. Goodluck WR. | |
09-30-2005, 15:38 | #6 (permalink) |
Insane Poster Join Date: Oct 2003
Member: 40695 Status: Offline Thanks Meter: 2 | x70 dead too and no solution mate its definitily INFINITY TO BLAME FOR ALL THESE DEAD PHONES . I HAVE HAD THE SAME PROBLEM .ITS A31 TRIED TO unlock first but it said operation failed .but the phone was ok. so i flashed a39 and tried to unlock it .this time it just err writing1 err writing than the dead phone.if it s happening to lot of people there must be something with the infinity .i have unlocked many phones with the griffin server before and not a single one them had any problem . why dont they update the software /or tell us how to fix the problem ? |
09-30-2005, 15:46 | #7 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Americas Age: 44
Member: 43802 Status: Offline Thanks Meter: 36 | I have unlocked a few X70's OK with Infinity Can anyone fix these dead X-70. I have one that restarts after first unlock with infinity. Use CB2000, then unlock a second time. now phone is totally dead. Winmodo cannot dectect it. charge battery in another phone, but phone still won't power on. Where can we send them to be repaired ? have to pay out of pocket to angry customer |
09-30-2005, 16:41 | #8 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 93717 Status: Offline Thanks Meter: 1 | I unlock many x70 no problem, but now I have one which die during unlock, it is version a32, there was error during writing, I try to unlock again and infinity said phone is unlocked but now it won't power on, also cannot flash with winmodo (it cannot detect phone) error log below Device have to be SWITCHED OFF Press Power button now... Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3/1... SW Version: GAX70A3232040408 FLASH-ID: 89000D88 Action-3/2... Err: write2: 00004020 Err: write2: 00004824 Err: write2: 00004824 Err: write2: 00004824 Err: write2: 00005028 Err: write2: 0000582C Err: write2: 0000582C Action-3 Failed[] Operation Failed Finished Then I try again Device have to be SWITCHED OFF Press Power button now... TestMode Ok Set Baud... Set Baud Done Parameters... SW Version: GAX70A3232040408 FLASH-ID: 89000D88 Parameters Done Check data... STEP-02 in progress... Check data Done Check HW... FLASH supported[89000D88] Check HW Done Operation... Working, don't interrupt... Action-1 Ok Action-2 Ok Action-3 Ok FLASH-ID: 89000D88 Action-4 Ok Action-5 Ok Action-6 Ok STEP-2 complete ! Operation Done Process completed Phone Unlocked Ok ! Remove/Install battery now ! Finished any solution for this phone. thanks |
10-02-2005, 16:34 | #10 (permalink) | |
Try to flash phone with Winmodo. Winmodo have to detect phone for sure, but it can be that flashing process stopped at the beginning. I need to know what error Winmodo say. | |
10-02-2005, 16:56 | #11 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Near phones Age: 46
Member: 18303 Status: Offline Thanks Meter: 3 | Well there si some problem with these X70 fones with A32 version.But u can revive for shure with flashing A39 using winmodo.About this error while unlocking is really strange ...i also experienced it once but revived the fone later with flashing.Just use full charged battery and flash it....will be ok.Wish you good luck with flashing. |
12-14-2005, 16:47 | #13 (permalink) |
Junior Member Join Date: Dec 2005
Member: 206017 Status: Offline Thanks Meter: 0 | i just done a successfull unlock of x70 but is not power on , but unlocking process is done very nicely , but fone is not comming on , phone comes on only when i press unlocked button again. any body knows why , lcd is fine no power at all battery 100% charged, or infinity is a useless now. |
12-14-2005, 16:57 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Could you please describe more exactly what is with phone ? What do you mean "phone comes on only when i press unlocked button again" ? Also, give me Log file to check. |
X70 Call RejectedHi infinity team i have 2 panasonic X70 one is when i making a call | Nasmi | Infinity-Box | 13 | 11-18-2005 00:18 |
x70 death | RRRRR | Infinity-Box | 10 | 07-30-2005 21:33 |
