Old 11-22-2008, 08:32   #1 (permalink)
Member: 333417
Sonork: zakariya
c140
unlocking problem
Current device: C140
Done
Action: unlock
Device: C140
Phone must be powered-On
Connecting...
device found: C140JPGD1
phone connected, working...
software version: C140JPGD1
hardware revision: MP 0.901
hardware id: C140
imei: 3537**********
working...
error: probably error during operation
Finished, time used: 39 sec
Remove/Install battery now !
Action: unlock
Device: C140
Connecting...
hardware id: C140
imei: 3537********************
working...
Finished, time used: 27 sec
Old 11-22-2008, 08:35   #2 (permalink)
laxman kumar's Avatar
Member: 733702
Sonork: 100.1579452
Thanks Meter: 580
download the optiflash.exe than flash it after unlock it
The Following User Says Thank You to laxman kumar For This Useful Post:
Old 11-22-2008, 09:11   #3 (permalink)
dharmeshslnk's Avatar
Member: 385162
Thanks Meter: 598
bro go to C:\Program Files\InfinityBox\Samsung01\OptiFlash_4.14T
there is opti flash you make flash your phone then unlock.
The Following 3 Users Say Thank You to dharmeshslnk For This Useful Post:
Old 11-22-2008, 11:03   #4 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
my c140 not connect what is problem or cable problme
Old 11-22-2008, 11:44   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You need to double check cable, probably you need to swap RX <-> TX wires.
Old 11-22-2008, 11:51   #6 (permalink)
Member: 333417
Sonork: zakariya
When it verify or write flash there is error shown [error bad srec addr] please help
Old 11-22-2008, 12:08   #7 (permalink)
Member: 130995
Hello,
Please, see step-by-step instruction here: C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Unlock_Samsung_c140_Airtel_India
Old 11-22-2008, 12:30   #8 (permalink)
Member: 333417
Sonork: zakariya
I E1 16:58:04 OptiFlash 4.14 T started
I E2 16:58:15 PC transfer speeds (COM8): 57600 115200 230400 460800 921600
I E3 16:58:15 Loading S-record file (RangeCheck=Off)
I E4 16:58:15 File: D:\Program Files\InfinityBox\Samsung01\OptiFlash_4.14T\sl_sce ptre3_nice_std.sre
I E5 16:58:16 SRE line 179: IGNORING: S70504001000E6
I E6 16:58:16 There is 1 memory region in the S-record file:
I E7 16:58:16 1: 0x04001000 - 0x04001b13 = 2836 Bytes
I E8 16:58:16 Loading S-record file (RangeCheck=Off)
I E9 16:58:16 File: D:\Program Files\InfinityBox\Samsung01\OptiFlash_4.14T\fl_sce ptre3_nice_std_v24.sre
I E10 16:58:16 SRE line 1188: IGNORING: S70500000000FA
I E11 16:58:16 There is 1 memory region in the S-record file:
I E12 16:58:16 1: 0x00000000 - 0x00004a2b = 18988 Bytes
I E13 16:58:16 Loading S-record file (RangeCheck=On)
I E14 16:58:16 File: D:\Program Files\InfinityBox\C140IDDGD3_BIN.s3
I E15 16:58:16 SRE line 1: IGNORING: S00600004844521B
I E16 16:58:16 SRE line 6402: IGNORING: S705A002000058
I E17 16:58:16 There is 1 memory region in the S-record file:
I E18 16:58:16 1: 0x00008000 - 0x00020fff = 102400 Bytes
E E19 16:58:16 Attempt to write to reserved region 0x8000 - 0x1ffff (0x8000 - 0x20fff)
I E20 16:58:16 Error code: ERR_BAD_SREC_ADDR
E E21 16:58:16 Sorry, an error has occured ! (ERR_BAD_SREC_ADDR)
Old 11-22-2008, 12:47   #9 (permalink)
Member: 130995
Hello,
Please, double check that you have set all values according to manual (pictures)
Old 11-22-2008, 12:51   #10 (permalink)
Member: 333417
Sonork: zakariya
thanks very much just i solve my problem
>> To Unlock C140 same procedure C139 << GsmTower Motorola ODM 8 09-26-2009 07:59
C140 hang on c140 at startup plz help asif_ae Samsung Hardware Repair 1 04-26-2009 14:38
Sch-c140 janjaroen UST Pro II 4 03-01-2007 10:15
c140 dead gabriel148 Infinity-Box 9 11-24-2006 12:00
c139/c140 Please urgent need C139 spanish language flash! micls17 Motorola ODM 10 10-05-2006 22:03
Page generated in 0.19354 seconds with 10 queries
