12-04-2008, 10:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: TUNISIA-KEBILI Age: 44
Member: 108627 Status: Offline Thanks Meter: 307 | Successfully Unlocked Sony-Ericsson-T303 module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-8242 software version: R2BB012 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20081204-102524.80E.bin Read data done Check data ... Check data done Write ... ............................ flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 198 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to limem2003 For This Useful Post: |
12-04-2008, 13:24 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
12-06-2008, 06:32 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: inside the pcb board
Member: 568876 Status: Offline Thanks Meter: 99 | OM8 [VCP0] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 49 sec Remove/Install battery now ! me i have problem unlocking se t303.... always stock on finalizing then got an error... its lock on vodafone....infinity team please take a look on my problem...TIA... |
12-06-2008, 08:09 | #4 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 235448 Status: Offline Thanks Meter: 18 | it worked fine thanks infinity team COM10 [VCP0] selected Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20081205-230420.80E.bin Read data done Check data... Check data done Writing... ........................... flash: 89890400040089:89890400000000 Write: simlock Writing done Finished, time used: 234 sec Remove/Install battery now ! |
12-12-2008, 11:24 | #10 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | error: operation failed COM4 [VCP0] selected module v1.30 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 47 sec Remove/Install battery now ! |
how to unlock sony ericsson t303 [CLOSED] | SUUNNYY | PolarBox 3 | 17 | 06-25-2009 20:12 |
Help needed for unlocking sony Ericsson T303 | Daywalker_zed | Phone Unlocking Codes & Maps | 2 | 05-12-2009 20:28 |
cant unlock sony ericsson t303 | tahataha | Universalbox | 1 | 05-01-2009 15:20 |
how to unlock sony ericsson T303 | ogiuwa | D-Unlock Suite | 1 | 01-24-2009 15:05 |
how to unlock sony ericsson t303 with tornado ufs3+hwk | mikelectronic | HWK | 1 | 12-28-2008 16:49 |
