05-28-2008, 18:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | LG KG270 Using pinfinder now unable to connect Loading data, wait... [Infinity Box] v1.47 S/N: 4389:010E Wait... Current model: LG KG270 Ready Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KG270P16-92-V10e-***-XX-JUN 20 2007+0 imei: 35744601822350700 Done Finished Loading file v.02... KG270P16-ESA-V10b-***-XX-Apr-17-2007+0_firmware.B1M.bin loaded Loading file v.02... KG270P16-ESA-V10b-***-XX-Apr-17-2007+0_LP_En_Th_Indonesia.B1P.bin loaded COM10 [VCP0] selected Device: LG KG270 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL KG270 P16 92 V10e ***-XX Jun 20 2007 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG270_eeprom-sta_20080528-184113.B1E.bin loading data... data loaded imei: 35744601822350700 reading [eeprom-sec_35744601822350700]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG270_eeprom-sec_35744601822350700_20080528-184118.B1E.bin reading [eeprom-complete_35744601822350700]... file saved: C:\Program Files\InfinityBox\Pana01\backup_LG KG270_eeprom-complete_35744601822350700_20080528-184126.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware At this moment power droped of computer so unable to get back in same status gettin problem in conectivy.' |
05-28-2008, 19:04 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Check battery voltage, charge it with external power supply and repeat flash process. In case of problems post here log, but I think everything should be Ok. |
unable to connect kp 199 in lg kp tab | sekharsun28 | ET-BoX | 1 | 10-02-2011 17:12 |
Unable to connect LG GD900 via usb | Gsm-W | VygisToolbox | 14 | 12-17-2009 06:12 |
cid changed on lg 8110 now unable to flash | nokia_dan | Cruiser Suite | 3 | 01-16-2006 19:07 |
Unable to connect using RS-232 Cable | ToM@to | Sony Ericsson | 5 | 12-07-2004 11:31 |
MYX1 error while flashing! now unable to connect the phone to the soft??? | AE177 | SagMaster Team OLD Products | 7 | 09-20-2004 21:14 |
