06-30-2014, 08:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | 2nd in the world micromax x321 read info and read flash done with infinity cm2spd:) READ INFO Code: Operation : Check/Read Info [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Done! Elapsed: 00:00:25 READ FLASH Code: Operation : Read FullFlash [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Compile : (<$QFq5*_1q%UVl˪FHHS1DSi%J%uAгb8{xXzNsxwrrB:mzc9cÔ?Nz5+ovٞ.I\r1fJB.\ymէa2rLb]01TzaN}e$Y-| A_Qt<!$Lbp0+rZ6\H&o迵hQ.x! ʹ,颋?nSqA~BN*櫦<StMѱ`),zĬUHcF<QQtGc/=U˵(4F2<-) $߯g-1HK"])fU؉AE§qLx y]&1Ұ 6zyj2~{*$Ѭ?̙2jJ\oVz?YU7YIhLNjwt&}6& D jشԮO۴0`8>LmJPG ,_9fdu*9lY+mсwXS;;cl9|*xxjhiXЂ]1BnTÅƑzoǶ c AOI3:/,L:1BZsCl[F6|;qi0?Bdэy*\>(wm!ZN}T,jV\mH4&u.wT$vO9E$;_V7tUw;ro~`MetdN*ń-!ry#᫄܌ i\P6/!_W7&CH$we$}V%DbU ? Set FileInfo : Model Vendor : MICROMAX Model Name : X321 ExtInfo Data : ENGLISH-HINDI Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_00800000__ENGLISH-HINDI__MICROMAX -X321.bin Done! Elapsed: 00:01:13 FORMAT FS/RESET PHONE Code: Operation : Format File System [ v0.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 31 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:15 Reconnect Power/Cable! REPAIR SECURITY Code: Chinese Miracle II [SPD module] v 0.07 Operation : Repair Security [ v0.07 ] Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 43 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : ExtInfo : GST_SP29_X321_MMX_M21_6464_EH_V17_20130411 Project : SC6530_BAR HWInfo : SC6530_BAR Compile : 04-11-2013 17:32:12 Phone Security Info : IMEI [1] : 352273017386340 IMEI [2] : 352751019523267 BT_ADDR : 00685866FB0B Read Ok! Write new security data : IMEI1 : 911307404841519 IMEI2 : 911307404841527 Write done! Elapsed: 00:00:03 Reconnect Power/Cable! READDED FLASH FILE:- SPD6530_00800000__ENGLISH-HINDI__MICROMAX -X321 - Download - 4shared - sahil roy WBR sahil2000ind |
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post: |
