Old 01-21-2012, 16:37   #1 (permalink)
Member: 159105
Thanks Meter: 60
motorola gleam
hi infinity team
i read only general information for motorola gleam (ex211) with lg gm750
Action: read/check information
Modèle: _Autodetect MT6253 NOR
Contrôle des données, attendre ...
téléphone doit être allumé!
En route, attendre ...
Téléphone détecté, attendre ...
Hardware version: MT6253, E04
Hardware version: CELLONSZ53_QUARTZ_09B_HW
Software version: QUARTZ_MAINCODE_24"
Software date: 2000.00.00
Barcode: 63EE11108022750 110
imei-1: 356382045059922
Terminé, temps utilisé: 4 sec
Retirez / remettre la batterie maintenant!
my b you can provid unlock solution with infinity box?
File Type: png B2C_EX211_Red_FrontOpen_EMARA_alt-FR.png (59.2 KB, 36 views)
Old 01-21-2012, 22:59   #2 (permalink)
cavalierks's Avatar
Member: 1523083
Sonork: 100.1609029
Thanks Meter: 141
try smart clip or lgtool
Old 01-22-2012, 09:28   #3 (permalink)
Member: 159105
Thanks Meter: 60
i now is supported by lgtools and smartclip thks but i hope infinity added it to
Old 01-22-2012, 17:18   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please read out full flash and send to [email protected]
include full phone's description
we will check it. thank you in advance!
Old 01-24-2012, 09:25   #5 (permalink)
Member: 159105
Thanks Meter: 60
hello!
i can read only general info
Old 01-24-2012, 13:49   #6 (permalink)
Member: 148515
hello!
what happens if you make "read full flash"?
can you post log?
dont forget to select 6253NOR!
Old 01-24-2012, 16:57   #7 (permalink)
Member: 159105
Thanks Meter: 60
COM4 [VCP0] selected
module v3.26
Périphérique: Autodetect 6205-6239 NOR
détection avancé de flash activé
Action: read flash
====> Boot ...
Appuyez et restez appuiez sur le bouton "Power" dès maintenant!
19200 fixed
Initialisation [6253:8A04:8A00]...
CPU: MT6253
haute vitesse de démarrage On
chip: 0000:0000:A00F
status: 03
taille de paquet de démarrage: 0400
erreur: bootcode start error: A4 not authorized: 000000A4
lachez bouton d'alimentation maintenant!
Boot Done
====> Initialiser ...
erreur: no any expected answer : wrong answer after chip cfi request
le nombre de puce flash / régions détectés: 00/01
flash chip is unknown or damaged.
Fault reasons:
1. flash chip is damaged: replace or resolder/reball flash chip
2. hardware is damaged: check hardware, water inside etc.
3. unknown hardware: set "méthode Avancé pour détection de chip" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialiser Fail
Terminé, temps utilisé: 25 sec
Old 01-24-2012, 17:00   #8 (permalink)
Member: 159105
Thanks Meter: 60
module v3.26
Périphérique: Autodetect 6253 NOR
Action: read firmware NAND
interface: BROM_DLL_v3.1016.00
Connect ...
téléphone doit être éteint!
bootcode current/expected: 0.0/3.2
CPU: 6253:8A04:8A00
status: 00
bbchip bl ver: 00
NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D
chip size: 0Mb
otp status/size: S_DONE/00000000
NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C
chip size: 0Mb
page/spare size: 0000/0000
pages per block: 0000
bits i/o: 00
address cycles: 00
internal RAM size: 00000000
external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000
sec error code: 00
erreur: can not boot device: 07E9:S_BROM_LOCK_POWERKEY_FAIL
erreur: last error: 07E9:S_BROM_LOCK_POWERKEY_FAIL
Disconnect...
bien
Terminé, temps utilisé: 11 sec
Old 01-25-2012, 13:46   #9 (permalink)
Member: 148515
hello!
you have to download latest Mmodule 4.13 for this operation.
upgrade your box to ver. 1.18 for using it
Old 06-01-2012, 22:15   #10 (permalink)
Member: 1300364
Thanks Meter: 23
hello!
COM3 [VCP0] selected
module  v4.28
Device: _Autodetect MT6250-6253 etc.
Checking data, wait...
Action: read flash NAND
interface: BROM_DLL_v3.1108.00
Connect...
CPU: 6253:8A04:8A00
status: 03
bbchip bl ver: FE
chip size: 0Mb
chip size: 0Mb
bits i/o: 00
address cycles: 00
sec error code: AB
error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE
error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE
Disconnect...
done
Finished, time used: 17 sec
Remove/Install battery now !
The Following User Says Thank You to [email protected] For This Useful Post:
G.M. 's GSM Links Nokia Siemens Trium Motorola Sagem GM GSM Mobile Links 0 06-18-2000 09:04
Updated site... Motorola BOX, Nokia Clip... mihut GSM Mobile Links 0 05-29-2000 02:52
I have unlcoker for 51/61/32 for all new version for exchange Motorola 3*88 unlocker! MC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-14-1999 13:02
Soft for Motorola with cable... florin_m GSM Mobile Links 3 10-11-1999 14:44
Ericsson-Motorola-Siemans unlock solutions dave GSM Mobile Links 0 08-27-1999 19:46
Page generated in 0.22461 seconds with 11 queries
