it 5020 SPD-6531 I tried to connect this phone for reset phone lock . But failed to connect it. I tried with usb cable and volcano Jig and also i short GND with Empty but no luck. I dont have boot cable is it possible to service this phone without spd boot cable. Or some one cab tell me how can i make my own cable if possible. . I saw some people they already done this dob. http://forum.gsmhosting.com/vbb/f715...x-key-2230863/ http://forum.gsmhosting.com/vbb/f715...e-box-2175478/ http://forum.gsmhosting.com/vbb/f457...-file-2180129/ https://www.hard-reset.in/images/android_boot_cable.jpg http://s23.postimg.org/49b8wr8i3/images.jpg http://i.imgur.com/al4dC8T.jpg i try this all but failed. |
Short with usb not uart Sent from my iPhone using Tapatalk |
Hello, Short TX with gnd and try and post result Sent from my S_plus using Tapatalk |
Wich one is boot key plz help |
use pin finder by box , it tries each key one by one . |
Bro, y so much stress because of this small phone? |
This phone have vol up and vol down if yes press this two keys and insert USB |
itel it5020 fully supported by cm2spd check here... Operation : Check/Read Info [ v1.26 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.26 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 22 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! boot key :- centre button still u have problem to connect....may be ur spd driver issue kindly try another port, pc, or reinstall spd driver regards, mobi_soft |
