Old 06-19-2017, 09:54   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 890
it 5020 SPD-6531
I tried to connect this phone for reset phone lock . But failed to connect it.
I tried with usb cable and volcano Jig and also i short GND with Empty but no luck.
I dont have boot cable is it possible to service this phone without spd boot cable. Or some one cab tell me how can i make my own cable if possible. . I saw some people they already done this dob.
itel it1512 Stuck On Logo Solved By Flash With Miracle Box & Key
Itel it5020 SPD6531 Read Phone Lock Code Done By Miracle Box
http://forum.gsmhosting.com/vbb/f457...-file-2180129/
i try this all but failed.
Old 06-19-2017, 11:32   #2 (permalink)
georgeodoom's Avatar
Member: 2296236
Thanks Meter: 128
Short with usb not uart
Sent from my iPhone using Tapatalk
Old 06-19-2017, 13:06   #3 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 890
thanks my friend. I already explained that i have shorted with usb and also with RJ45 but same problem. i tried with direct connecting on board direct RX TX but same story..
Old 06-19-2017, 14:40   #4 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 648
Hello,
Short TX with gnd and try and post result
Sent from my S_plus using Tapatalk
The Following User Says Thank You to princesaddam For This Useful Post:
Old 09-19-2017, 15:19   #5 (permalink)
NadeemSandhu1's Avatar
Member: 2077858
Thanks Meter: 124
Wich one is boot key plz help
Old 09-20-2017, 21:42   #6 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 349
use pin finder by box , it tries each key one by one .
Old 10-26-2017, 23:02   #7 (permalink)
Member: 2077858
Thanks Meter: 124
I did done with EDL Cable and center key is the boot key
Old 10-26-2017, 23:13   #8 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,970
Bro, y so much stress because of this small phone?
Old 10-26-2017, 23:13   #9 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,389
This phone have vol up and vol down if yes press this two keys and insert USB
Old 12-26-2017, 06:03   #10 (permalink)
mobi_soft's Avatar
Member: 1126941
Sonork: 100.1672154
Thanks Meter: 2,478
itel it5020 fully supported by cm2spd
check here...
Operation : Check/Read Info [ v1.26 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 22 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Elapsed: 00:00:03
Reconnect Power/Cable!
Operation : Format File System / Reset Settings [ v1.26 ]
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 22 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:16
boot key :- centre button
still u have problem to connect....may be ur spd driver issue
kindly try another port, pc, or reinstall spd driver
regards,
mobi_soft
Page generated in 0.30263 seconds with 7 queries
