Old 02-15-2011, 12:37   #1 (permalink)
jr astigin's Avatar
Member: 757159
Thanks Meter: 467
5310 dual sim help?
COM50 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:4D03:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:18C59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18D09FC518D09FC518D09FC518D09FC518D09FC518D09FC5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: SCUD_GEMINI_PCB1_GPRS_MT25_S067B_A_V0.BIN
project-id: 67B_A.V0, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 1 min 28 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Successful format but the unit cannot power on
Can anybody have same firmware like this
Old 02-15-2011, 14:44   #2 (permalink)
sunny box's Avatar
Member: 1456392
Sonork: 100.1606104
Thanks Meter: 115
hardware problem bro...
Old 02-16-2011, 02:36   #3 (permalink)
jr astigin's Avatar
Member: 757159
Thanks Meter: 467
an you give me same firmware like sw version: SCUD_GEMINI_PCB1_GPRS_MT25_S067B_A_V0.BIN
Old 02-16-2011, 05:31   #4 (permalink)
Member: 836414
Thanks Meter: 17
wow........reheat the cpu or what we called (mtk)...see and your china mobile phone will be okey...
Old 02-16-2011, 05:40   #5 (permalink)
jr astigin's Avatar
Member: 757159
Thanks Meter: 467
but i already try to flash with other firmware from support i dont have backup..an you give with the same firmware?
Old 02-17-2011, 20:24   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
seems available on our support site:
flashfiles/ChineseMiracle/_MT6205-MT6227/SCUD_GEMINI_PCB1_GPRS_MT25_S067B_A_V0_16m.B0M.bin
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.26424 seconds with 9 queries
