Old 08-06-2008, 06:32   #1 (permalink)
Member: 700923
Thanks Meter: 13
Question 5310 flash error
COM1 [Serial0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:FF0F:FFFF
boot step size: 0400
error: bootcode start error: A4 not authorized: 000000A4
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 12 sec
Remove/Install battery now !
Old 08-06-2008, 06:40   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Fail
try too bandrate set low rate, i think this is flash ic fault, rehit or reball flash ic.
Old 08-06-2008, 12:32   #3 (permalink)
Member: 148515
Thanks Meter: 15,719
hello!
how did you find pinout? using pinfinder?
please repeat procedure few more times and post reply if you see this problem every each time
Old 08-11-2008, 23:51   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,401
@w850
Please, make this:
1. download latest MModule v2.29: http:///vbb/showthread.php?t=578675
2. Select model Alcatel-S520
3. Try to read flash
In case of success send flash backup with information about problem and phone to: [email protected]
incluse operation.log file in your mail
Let's see results
5310 Flashing error. Nikil J.A.F. By Jafsupport.com 5 10-27-2011 09:51
5310 flashing error!!!! Done with RIGHT cable Byte MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 04-21-2009 18:44
5310 flash error mobi-trend Nokia Base Band 5 ( BB-5 ) 0 01-22-2009 09:28
Page generated in 0.26714 seconds with 8 queries
