01-29-2009, 18:41 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | 5310 flash file needed it was is light blinking. I format it. safe mode complete mode safe mode selected items. int he end I format it whole flash chip. after last option set is in dead condition. I also reball its cpu and flash chip. and then try all process again.but all in vain. now I m looking to flash it. but unable to find its flash file. can some one provide me its flash file. |
01-30-2009, 21:32 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, In this kind of situation let's hope that somebody can detect required version by phone photo. Btw, do you see any marks at phone PCB ? |
02-01-2009, 11:41 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would advice to go chinese miracle folder. open with any text editor file named "operation.log" scrool it up from the end and look for operation you made with this phone. find very first operation, there you will see phone Original version. post it here, we will try to advice flash file |
02-02-2009, 07:12 | #9 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | ==== log opened: [1/27/2009 7:42:24 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/27/2009 7:42:41 AM] ==== COM3 [VCP0] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 217 sec Remove/Install battery now ! ==== log opened: [1/28/2009 12:27:46 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done COM3 ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/28/2009 12:28:06 AM] ==== COM3 [VCP1] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 328 sec Remove/Install battery now ! ==== log opened: [1/28/2009 1:10:15 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/28/2009 1:10:42 AM] ==== COM3 [VCP0] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1803:0007 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 129 items cleared: 19 of 129 items remains: 0 Finished, time used: 551 sec Remove/Install battery now ! ==== log: [1/28/2009 1:22:36 AM] ==== COM3 [VCP0] selected module v2.73 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350447571234565 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1803:0007 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 0 done 44 byte(s) read verification... verification failed, Power On/Off phone and repeat operation error: operation failed ! Finished, time used: 18 sec Remove/Install battery now ! Imei 35044757123456 already was repaired: 1/28/2009-1:23:00 AM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: GINWAVE25_06B_HW Software version: FXD-S3_FOREIGN_MR106 Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 350447571234565 verification Ok Finished, time used: 6 sec Power off phone now ! ==== log opened: [1/28/2009 7:41:25 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done COM3 ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/28/2009 7:41:46 AM] ==== COM3 [VCP1] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 38 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/28/2009 7:42:58 AM] ==== COM3 [VCP1] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 66 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/28/2009 7:44:12 AM] ==== COM3 [VCP1] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3A03:0000 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 170 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/28/2009 7:47:18 AM] ==== COM3 [VCP1] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3A03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN ver. sw 2: A90V1.6.1, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN]_20090128-074908.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 126 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [1/28/2009 7:50:54 AM] ==== COM3 [VCP1] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3A03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN ver. sw 2: A90V1.6.1, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done Finished, time used: 57 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [1/28/2009 7:56:32 AM] ==== COM3 [VCP1] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: erase flash chip eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3A03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN ver. sw 2: A90V1.6.1, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN]_20090128-075800.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Erase: chip 1 of 1 Finalization Done Finished, time used: 212 sec Remove/Install battery now ! ==== log opened: [1/28/2009 8:06:21 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [1/29/2009 6:24:40 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [1/29/2009 7:10:19 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done ==== log opened: [1/29/2009 9:26:53 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 25C7:0112 Wait... Device: Autodetect 6205-6227 NOR Done |
02-02-2009, 11:49 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! in provided above log i can see 2 phone versions: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1 can you figure out by date/time which one is from your dead set? |
02-03-2009, 07:52 | #11 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | Sorry boss I think I have lost my actual logs. because current logs start from 2nd february 2009. while I format my handset before 29 january 2009. I think ,I uninstall infinity software and install again. therefore I lost all my data in c/program files/infinity....... u try to upload any kind of file related to xpress music 5310. I will try and check result. |
5310 china flash file.needed see attach image | dawgweed | Infinity-Box | 4 | 12-15-2013 07:15 |
5310 flash file need urgent.... | /FAISAL/ | Infinity-Box | 2 | 04-23-2009 17:18 |
rm-303 5310 flash files needed please | toutou_gsm | Nokia Base Band 5 ( BB-5 ) | 3 | 03-31-2009 18:24 |
NCKIA 5310 Expressmusic flash file needed | Unicom | Infinity-Box | 3 | 09-20-2008 12:52 |
NCKIA 5310 Expressmusic flash file needed | Unicom | SpiderMan | 2 | 09-19-2008 19:31 |
