03-22-2008, 06:23 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 471557 Status: Offline Thanks Meter: 13 | 5310 flashing COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3A03:000A boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 29 sec Remove/Install battery now ! is this in the cpu or flash ic. should replace the flash ? than****** |
03-22-2008, 11:49 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! looks like flash IC is dead but worth to try disable "Advanced chip detection method" and use different boot steps 2,10,1000 each time try to boot phone. if this will not help- focus on hardware repair |
03-22-2008, 12:20 | #4 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | 5310 sir i try the reply you post but 1st display only nokia then hang i take off the bat a try it again and this error occure. log COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3A03:000A boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd PL127J D 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd PL127J D 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 11 sec Remove/Install battery now ! the speed in this set up is very low no others avail 115200 and i did not understand the 2 , 10 , 1000 you post... thaanx in the reply |
03-22-2008, 13:24 | #5 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | 5310 sir the phone was ok now it have the power now.......i just observe it until tommorw... thanx in your advice... thn*** in the advice i just reheat boot flash and cpu hope it will not hang hehehe |
5310 Flashing error. | Nikil | J.A.F. By Jafsupport.com | 5 | 10-27-2011 08:51 |
5310 flashing problem | tayseer | Nokia Base Band 5 ( BB-5 ) | 1 | 09-25-2008 01:56 |
nokia 5310 flashing problem (adl loader not start) | gsmbac | Multi-Box | 6 | 04-06-2008 03:34 |
