01-07-2009, 09:46 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 144091 Status: Offline Thanks Meter: 73 | 5310 no power after format - help after format it's now dead here is the backup http://rapidshare.com/files/18063141...-3-31.BIN.html TIA |
01-07-2009, 11:16 | #4 (permalink) | |
Member: 144091 Status: Offline Thanks Meter: 73 | Quote:
MT6226 (anyway it's indicated in the flashfiles uploaded) @Infinity I already used several flashfiles from support match with this 5310 but no one did work. i will post picture later. thanks | |
01-07-2009, 11:17 | #5 (permalink) | |
01-07-2009, 15:31 | #7 (permalink) |
Member: 144091 Status: Offline Thanks Meter: 73 | i could twist this 5310 into pieces. now it just turned on using flash flash from infinity in which i had already flashed several times lately. anyway thanks to infinity...mwah! lesson learned just use infinity SW and it's best here is log COM3 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:E5AF:4C49 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: 0A1585E5 identification#1 protocol ver: 04 ver. sw 1: D421_05C_PCB01_GPRS_MT6226_S01.GM699-V01-2008-3-31.BIN ver. sw 2: GM699-V01-2008-3-31, 2C0234E4 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 430 sec Remove/Install battery now ! |
[help] 5310 no display after repair LCD no light | thonylvs | Nokia Hardware & Hardware Repair | 0 | 01-14-2010 03:33 |
no power after unlocking siemens a71 help | maxheadquarters | Siemens Hardware Repair Area | 0 | 02-23-2006 16:27 |
F2100 no power after flash , help pls.....! | BMobile | VygisToolbox | 4 | 09-06-2005 17:48 |
Help me K700 no power after bad charger... | uti79 | Sony Ericsson Hardware Repair | 0 | 07-06-2005 08:31 |
6510 no power after flashing,help!!!! | michaelcaine22 | Nokia Hardware & Hardware Repair | 3 | 02-20-2005 00:33 |
