09-15-2008, 07:48 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | 5310 problem .. dead.. COM16 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:BB03:000D boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 39 sec Remove/Install battery now ! |
09-16-2008, 11:24 | #4 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | i think brother see flash ic numbers and words at flash ic that is damaged. and look after for same flash ic that have same words and numbers. i think u understand what i say. |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
09-16-2008, 16:41 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! in most cases it is just bad soldering problem, so no need to look for new flash IC just resolder old one |
09-17-2008, 21:41 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you dont have enough skills in resoldering- just heat it. in most cases heating can solve problem |
Is this 5310 totally dead?? | richiricherd | Nokia Base Band 5 ( BB-5 ) | 4 | 05-16-2008 11:19 |
