02-21-2008, 11:11 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market. Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
02-21-2008, 19:13 | #4 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 583680 Status: Offline Thanks Meter: 47 | Hello Mr.Unlocker34! Please take a multimeter and measure each pins voltage starting from pin1 to pin12.Write down measuring results on paper and post them here like pin 1-xx.xx v pin 2-xx.xx v ........ pin 12-xx.xx v and will try to help You find correct pinout. |
02-23-2008, 01:39 | #5 (permalink) |
Crazy Poster Join Date: Sep 2005 Age: 41
Member: 178224 Status: Offline Thanks Meter: 4 | hello ezzis I am waiting for you help thanks /1 2 3 4 5 6 \ | 7 8 9 10 11 12 | 1: 3.91v 2: 2.60v 3: 2.70v 4: 2.76v 5: 0.74v green 6: 00 7: black gnd cable 8: 0.80v 9: 2.77v 10: 3.81v 11: 1.09v white 12: 0.31 usb charge red |
02-23-2008, 04:12 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @unlocker34 What is the reason to ask Mr. Ezziz to find pinout for you ? You have more than detailed instruction here and you able to make everything by yourself: http://67.15.194.130/vbb/showpost.ph...71&postcount=2 Please correct me if I am wrong. |
***5310 Xpress Music O2-uk Unlocked*** | allthingsmobile | Universalbox | 20 | 12-13-2008 11:58 |
Nokia 5310 Xpress music | buzz_ | Nokia Multimedia | 2 | 05-15-2008 17:16 |
5310 xpress music with infinity | omega-telecom | Infinity-Box | 2 | 04-08-2008 17:05 |
5310 xpress music pinout | jacekchec | MT-BOX | 0 | 02-20-2008 12:06 |
