03-15-2009, 11:29 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Manila
Member: 198113 Status: Offline Sonork: 100.161124 Thanks Meter: 95 | 6300 camera problem now dead ver. sw 1: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_24.BIN ver. sw 2: MAUI.GEMINI.W08.12.24, 00000000 |
03-15-2009, 21:56 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! take similar file, i am sure one of them will work for you. for example: [bin] flashfiles/ChineseMiracle/_MT6225/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_20__Nokia-6300_16m_En_Ru_Fr_Es_De_Ml_Id_Tr_Farsi_Pt_Cz_Ar.B0 M.bin |
03-16-2009, 12:27 | #3 (permalink) | |
Member: 198113 Status: Offline Sonork: 100.161124 Thanks Meter: 95 | Quote:
SIR BEFORE I POST THIS I USED THAT FILE FROM SUPPORT SAME FILE AS WHAT U POSTED BUT ERROR WRITE IN OTHER flashing is ok but dead result pls help me to find exact flash file for my phone ive send the logs from support u will see the logs of the fone by the thanks for fast reply | |
03-26-2009, 20:21 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this flash file 08_12_24 i decided not to upload. because sender did not confirmed its full functionality. try some similar flash file, for example [bin] flashfiles/ChineseMiracle/_MT6225/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_20__Nokia-6300_16m_En_Ru_Fr_Es_De_Ml_Id_Tr_Farsi_Pt_Cz_Ar.B0 M.bin |
03-28-2009, 04:36 | #12 (permalink) |
Member: 198113 Status: Offline Sonork: 100.161124 Thanks Meter: 95 | SIR WHAT DO YOU MEAN FORMAT COMPLETE AFTER FLASH OR FORMAT COMPLETE BEFORE FLASH THEN SAFE FORMAT, BECAUSE EVERY TIME I COMPLETE FORMAT THE PHONE I ALWAYS GET DEAD PHONES AND JUST WRITE THE BACKUP AGAIN IF THERE IS NO FLASH IN SUPPORT, BUT IN THIS CASE I FORGOT TO BACKUP THE FULLFLASH FIRMWARE I JUST BACKUP THE EEPROM< AND I DONNOT KNOW IF IT IS CORRUPTED OR NOT SO DECIDED TO REQUEST IT, BECAUSE I SEARCH IN FORUM THERE IS NOTING FLASH FIRMWARE LIKE AS I MENTION, AND ALSO IN OUR SUPPORT AREA, I APPRECIATE YOUR FAST REPLY BUT I NEED HELP FROM YOU TO REVIVE THE UNIT, I HOPE YOU UNDERSTAND BECAUSE MY CUSTOMER WAS ANGRY TO ME, I KNOW ITS MY FAULT SIR NOT YOURS, BUT I NEED YOUR HELP........ THANKS AGAIN regards bogg7 |
03-28-2009, 08:47 | #13 (permalink) |
Member: 198113 Status: Offline Sonork: 100.161124 Thanks Meter: 95 | here is the logs again sir til now no good flash file COM4 [VCP2] selected module v2.78 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F803:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:58ABFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:58ABFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:58ABFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:58ABFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:58ABFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:58ABFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 5870FFAB8433996DAFA8B4F6B9F90CA9381CB4F66BFA9A49 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000000:58ABFF00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00C00000 Detected ffs/eeprom address is non-standard: 00C00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00C00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:58ABFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000000:58ABFF00000000 Finalization Done Finished, time used: 130 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-28-2009, 14:56 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please do not confuse "Format whole flash chip" & "Format Complete" first one will erase whole flash chip and result will be dead phone. what i am advice here is try to use similar flash files. worth to try, for example, theese: [bin] flashfiles/ChineseMiracle/_MT6225/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_30__Ben_16m_En_Ru_Fr_Es_Id_Tr_Farsi_Pt_Ar.B 0M.bin [bin] flashfiles/ChineseMiracle/_MT6225/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_14_16m_En_Ru_Fr_Es_De_Ml_Id_Tr_Farsi_Pt_Cz_ Ar.B0M.bin just after flashing, disconnect battery, connect it again and make format FFS complete. only then try to power it On |
6300 camera problem | TITO | Nokia Hardware & Hardware Repair | 75 | 05-17-2013 21:57 |
6300 camera problem | Afzal Chiri | Nokia Hardware & Hardware Repair | 6 | 01-19-2010 21:21 |
3110/6300 camera problem | tiger43 | Nokia Hardware & Hardware Repair | 3 | 11-20-2009 13:50 |
6300 camera problem | SCOOTER_R | Nokia Hardware & Hardware Repair | 4 | 03-11-2009 16:52 |
