09-01-2008, 13:23 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | 6300 China problem Infinity help Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:8195:6AE1 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished identification#1 protocol ver: 04 ver. sw1: MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_50.BIN ver. sw2: V20.50, F06748B3 ffs offset/size: 00E00000/00200000 error: no any expected answer warning: security area#1 data invalid detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... error: unexpected termination/freez: 00000000 can't detect fat record name location ffs element #1 detection failed Check firmware integrity Done Check firmware content... detecting languages... error: unexpected termination/freez: 00000000 error: can't detect language parameter #1 can't detect language names if software not respond/freez: make "Find language names (slow process)" unchecked and repeat operation. Check firmware content Fail Finished, time used: 122 sec Remove/Install battery now ! photo link is here. http://www.2shared.com/file/3858549/...eenshot_4.html |
China nokia 6300 mic problem plz help! | guljee786 | Chinese Models & Cloned Phones | 3 | 06-28-2011 10:28 |
nokia 6300 china problem | chaudry | Chinese Models & Cloned Phones | 5 | 06-22-2010 12:25 |
6300 china flash file help.. | renxander | Chinese Models & Cloned Phones | 0 | 12-14-2009 08:43 |
6300 china phone pinout help | em2 | Chinese Models & Cloned Phones | 12 | 07-30-2008 13:32 |
6300 unlocking problem pl help me | ruvanw1979 | UID - Box | 9 | 11-16-2007 15:54 |
