02-23-2009, 08:13 | #1 (permalink) |
Freak Poster Join Date: May 2004
Member: 67367 Status: Offline Thanks Meter: 47 | 6300 chinese nokia Can anyone help me with my 6300 Chinese nokia phone. The problem goes like this, the phone will detect with my pin-finder, but when I'm with the infinity software trying to read full flash then when it says "Press and HOLD Power button now" there is no reaction. For me wrong pin-out may not be the reason coz it has been detected on pin-finder. What went wrong with my procedure? Can anyone help me with this mates? |
02-23-2009, 08:36 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
The Following User Says Thank You to deepakgarg For This Useful Post: |
02-23-2009, 09:37 | #3 (permalink) |
Member: 67367 Status: Offline Thanks Meter: 47 | I've already done that sir. Swap Rx and Tx, Power on and off problem sir still the same. I'm wondering that it won't detect coz base on the information given by the pin finder is this: Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:3 Tx:8 time required: 12 sec While on the infinity software the given Tx and Rx is this: Chinese-Nokia 6300 2. cable type: 1x10 pins 2: Gnd 3: Gnd 5: Rx 7: Tx 3. cable type: 2x5 (L10C) Can I ask if this might be the cause? What can i do for this mates? |
02-23-2009, 10:15 | #4 (permalink) |
No Life Poster Join Date: Jul 2006 Location: U-A-E Dubai---->Pak
Member: 315789 Status: Offline Thanks Meter: 3,428 | yes,check pin finder software if power is on or off and secondly check what com port you selected. Br |
The Following User Says Thank You to mughalG For This Useful Post: |
02-23-2009, 13:16 | #5 (permalink) | |
Member: 67367 Status: Offline Thanks Meter: 47 | 6300 no power solved Quote:
Thank you who help me with this concern specially deepakgarg and mughalG Gadget : Infinity Procedure * Open Shell * Select China Nokia * Select Model * Select RUN * Check COM Port (must be same) * Click Service Tab * Select Complete Mode * Format * Wrtie IMEI * Done | |
6300 chinese nokia dead | azad4u | Chinese Models & Cloned Phones | 1 | 10-13-2008 08:02 |
Another Chinese nokia 6300 | Bomber | Infinity-Box | 10 | 02-09-2008 16:45 |
Nokia 6300 chinese | ziasim | Infinity-Box | 6 | 10-13-2007 11:25 |
chinese nokia 6300 Q7 | ahmad bashir | Chinese Cocktail | 1 | 10-04-2007 18:56 |
Nokia 6300 chinese flash file | nokia6280 | Nokia Base Band 5 ( BB-5 ) | 0 | 05-11-2007 02:14 |
