09-16-2009, 03:12 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 6300 flash complete flsh but connot open module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware _fullflash_20090915-204744.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs _ffs_20090916-100027.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7618:80FE status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device rom info... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00700000 flash: 01227E22022201:FFFFFF00000000 checking area [00000000]: 00000000-007FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20090916-100511.B0E.bin flash: 01227E22022201:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device rom info... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished ffs address can not be detected, value from database assigned: 00700000/00100000 detect device sec info... detection phase #1... . detect device sec info finished detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 01227E22022201:FFFFFF00000000 Write: Firmware Area: Eeprom/ffs flash: 01227E22022201:FFFFFF00000000 Write: Eeprom/ffs detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done Finished, time used: 283 sec Remove/Install battery now ! any help me china 6300 complete flush but connot open thank you. |
09-16-2009, 04:10 | #3 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | OM12 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7618:80FE status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device rom info... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00700000 flash: 01227E22022201:FFFFFF00000000 checking area [00000000]: 00000000-007FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_fullflash_200909 16-102926.B0M.bin Finished, time used: 2124 sec Remove/Install battery now ! here in complete but connot open i need help |
09-16-2009, 06:29 | #5 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | COM12 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware CM_Nokia-6300-RM-217_LEDA26_06A_PCB01_GPRS_MT6226_S01[1].MAUI_06A_W06_48_26_16m_En_Cn.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7618:80FE status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 01227E22022201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device rom info... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00700000 flash: 01227E22022201:FFFFFF00000000 checking area [00000000]: 00000000-007FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... connot read ffs pls help infinity help this problem |
09-16-2009, 08:47 | #7 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | the problem is hung up i try to format and i using buck up files but after flush the phone not open i try to send buck up file error conot gat ffs see that . . . . . |
09-16-2009, 10:19 | #11 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | here in complete flush but not open. . . . . . . pls tell me what is problem this the phone not hardware i chick this .any have i dea COM12 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware CM_Nokia-6300_LEDA26_06A_PCB01_GPRS_MT6226_S01[1].MAUI_06A_W06_48_30_16m_En_Ru_Fr_Th_Vn_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7618:80FE status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:AADA0D00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:AADA0D00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:AADA0D00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:AADA0D00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:AADA0D00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9769BE1C.[T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V 0911A.BIN_33736E49].rpl rom info detection finished device-id: 9769BE1C rom info protocol ver: 04 ver. sw 1: T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V 0911A.BIN ver. sw 2: A7_NOKIA_ALLLANG_V0911A, B6918CCC ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22022201:29EA0000000000 checking area [00000000]: 00000000-007FFFFF... flash: 01227E22022201:AADA0D00000000 checking area [00800000]: 00000000-007FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 01 ffs/eeprom area: 00800000:00600000-007FFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V 0911A__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9769BE1C.[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_08_0 1.BIN_35204EA4].rpl flash: 01227E22022201:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device sec info... detection phase #1... . detect device sec info finished startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\T 6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V0 911A__system_log_9769BE1C_33736E49_20090916-170908.B0X.bin Area: Firmware flash: 01227E22022201:29EA0000000000 Write: Firmware jump to next chip: 01 flash: 01227E22022201:AADA0D00000000 Write: Firmware detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\T 6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_ALLLANG_V0 911A__system_log_9769BE1C_33736E49_20090916-171518.B0X.bin Finished, time used: 1009 sec Remove/Install battery now ! |
09-16-2009, 11:27 | #13 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | whose cant help me this problem pls i think is big problem for me this do i have i dea for this problem master of this any idea? |
09-16-2009, 12:00 | #14 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | COM12 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware CM_Nokia-6300_LEDA26_06A_PCB01_GPRS_MT6226_S01[1].MAUI_06A_W06_48_36_16m_En_Ru_Fr_Es_De_Th_Tr_Pt_Ar .B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs LEDA26_06A_PCB01_GPRS_MT6226_S01[1].MAUI_06A_W06_08_01___6300.B0E.BIN ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7618:80FE status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22022201:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:89C4B900000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:89C4B900000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: 01227E22022201:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: 01227E22022201:89C4B900000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: 01227E22022201:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: 01227E22022201:89C4B900000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22022201:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:89C4B900000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2B0000EA18F0000018F0970018F09F0018F09F0018F09F00 number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9769BE1C.[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_3 0.BIN_578C9B92].rpl rom info detection finished device-id: 9769BE1C rom info protocol ver: 05 ver. sw 1: LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_3 0.BIN ver. sw 2: MAUI.06A.W06.48.30, 6D6473A8 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22022201:2BEA0000000000 checking area [00000000]: 00000000-007FFFFF... flash: 01227E22022201:89C4B900000000 checking area [00800000]: 00000000-007FFFFF... ffs/eeprom found near: 00000000 Detected ffs/eeprom address is non-standard: 00000000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00000000 error: critical error#1 during ffs/eeprom size detection error: can't detect ffs/eeprom address/size detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_9769BE1C_578C9B92_20090916-185820.B0X.bin Finished, time used: 156 sec Remove/Install battery now ! |
Ku990i camera loading ang files connot open | i-Fixed | Z3X-Team Products | 5 | 09-29-2013 16:37 |
6300 flashing completed but cant power. heres log | kevin182029 | HWK | 13 | 03-03-2009 21:39 |
""n73 Flashing Completed Successfully But Not Pwer On - Logs Posted - Please Help Me" | rajeevpchandran | J.A.F. By Jafsupport.com | 8 | 06-20-2008 21:44 |
6300 flashing completed but no power!!! | Dee31 | Nokia Hardware & Hardware Repair | 4 | 10-01-2007 03:32 |
help me now my phone n90 can't boot up after flash the flsh complete but the phone no | dvdaio | Nokia Base Band 5 ( BB-5 ) | 2 | 05-24-2007 14:59 |
