04-28-2008, 00:45 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Stop WAR on GSM Business
Member: 328416 Status: Offline Thanks Meter: 42 | 6300 No Power I tried to format it but still died... heres the logs... COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1976:8F87 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98004900000002:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 98004900000002:FFFFFF00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:FFFFFF00000000 Finalization Done Finished, time used: 156 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Heres the log in Information... COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1976:8F87 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98004900000002:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ................................................ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ................................................ detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 201 sec Remove/Install battery now ! |
3110c-6300 No Power/Grounded Solution Here... | diabel02 | Nokia Hardware & Hardware Repair | 8 | 08-29-2011 03:39 |
6300 no power on | aliraqi | Nokia Hardware & Hardware Repair | 2 | 09-22-2008 14:11 |
yeah, another thread about 6300 - no power | Bmw1000c | Nokia Hardware & Hardware Repair | 2 | 08-26-2008 22:20 |
6300 no power | peym@n | Nokia Hardware & Hardware Repair | 0 | 06-21-2008 23:01 |
