04-13-2008, 13:43 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 471557 Status: Offline Thanks Meter: 13 | 6300 other pinout need help pls...... http://rapidshare.com/files/107141819/6300l.jpg.html http://rapidshare.com/files/10714194...6300l.jpg.html hope in your help...thanx..advance Last edited by shan969; 04-13-2008 at 13:52. |
04-13-2008, 21:53 | #2 (permalink) | |
I have prepared small instruction for you, hope it will help. In case of any future problems don't hesitate to ask more questions. There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en | |
04-14-2008, 11:55 | #3 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | 6300l sir i try the guide you have even searching in the pinout that the infinity have package still not working ....if some one have same board like this and also still getting the pin pls check this pin i try in the side of the board i think the rx,tx is here but i cant find it....... *#66*# Set Factory Mode CONFIRMEDis not working in the 6300 sir.. does 6300 have a manual reset....Factory mode: *#987# http://rapidshare.com/files/107358633/6300l__1_.jpg.html hope in your reply.. |
04-14-2008, 11:58 | #4 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | 6300l sir i try the guide you have even searching in the pinout that the infinity have package still not working ....if some one have same board like this and also still getting the pin pls check this pin i try in the side of the board i think the rx,tx is here but i cant find it....... *#66*# Set Factory Mode CONFIRMEDis not working in the 6300 sir.. does 6300 have a manual reset....Factory mode: *#987# hope in your reply.. |
04-14-2008, 12:01 | #5 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | 6300l sir i try the guide you have even searching in the pinout that the infinity have package still not working ....if some one have same board like this and also still getting the pin pls check this pin i try in the side of the board i think the rx,tx is here but i cant find it....... *#66*# Set Factory Mode CONFIRMEDis not working in the 6300 sir.. does 6300 have a manual reset....Factory mode: *#987# sorry for the many repost i have the internet problem in the shop..... hope in your reply.. |
04-17-2008, 04:31 | #6 (permalink) |
Member: 471557 Status: Offline Thanks Meter: 13 | new 6300L success by infinity here the log and pinout i what to share to all. to make other work easy to flash... log. COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:9DC1:0F5E high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.C9FE03D2.[RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_5T03 S1215.BIN_4AC838CA].rpl identification#1 detection finished device-id: C9FE03D2 identification#1 protocol ver: 04 ver. sw1: RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_5T03 S1215.BIN ver. sw2: R6300_03_0.5T03S1215, 35C737B5 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_5T03 S1215.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\6300\backup_flash[RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300_03_0_5T03 S1215.BIN]_20080416-043815.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _C9FE03D2_RATECH26_06A_PCB01_GPRS_MT6226_S01.R6300 _03_0_5T03S1215.BIN_4AC838CA_20080416-044014.B0X.bin Finished, time used: 1643 sec Remove/Install battery now ! this error come up when i sp lock the unit..so i did not try second time when i put sim it accept .....so no prob... COM1 [Serial0] selected Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:9DC1:0F5E Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: R6300_03_0.5T03S1215 Version: R6000_HW detecting structure #2... 0done 44 byte(s) read imei: 35790246811220 connection Ok detecting structure #1... 0 2 3 4 5 7 8 9warning: wrong packet cs 10warning: wrong packet cs 12 13 14 16 17 18 19 21 22 23warning: wrong packet cs 24warning: wrong packet cs 26 27error: detection failed (22 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! hope i can be big help to all ..... |
The Following 3 Users Say Thank You to shan969 For This Useful Post: |
06-26-2008, 05:40 | #9 (permalink) | |
Insane Poster Join Date: Feb 2008 Location: Narra, Palawan
Member: 703121 Status: Offline Thanks Meter: 37 | Quote:
sir can you send me the flash files that you used on this thread,, i need it very badly...... this is my YM: [email protected] | |
6300 China Pinout Need for this PCB | Amir-SkillZ | Infinity-Box | 3 | 09-06-2009 08:25 |
A6+ iphone pinout, need help pls........ | Redtan_70 | Infinity-Box | 1 | 12-18-2008 13:06 |
6300 china phone need flashfile pls... | carmelanicole | Chinese Models & Cloned Phones | 3 | 11-14-2008 19:37 |
To Willy Or Other EXPERTS ... Need Help | cellularcareazs | Nokia Hardware & Hardware Repair | 0 | 04-19-2005 06:35 |
