Old 04-20-2008, 11:17   #1 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
6300-Q7+ booting but giving error
im doing it for wit PCB
here logs
COM3 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:9E8A:470D
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 99 sec
Remove/Install battery now !
Old 04-20-2008, 11:36   #2 (permalink)
gsm-world's Avatar
Member: 582790
Thanks Meter: 378
head flash ic .................
Old 04-20-2008, 19:44   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
use complete format method instead
Old 04-21-2008, 07:47   #4 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
thnx sir my phone now on
Old 05-28-2008, 17:16   #5 (permalink)
ericnite101's Avatar
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Thumbs down 6300 Q7+ Flashing Ok but doesn't Power ON
I got my 6300 Q7+ Boot ok, Flashing completes but doesn't switch on. The flash file Am using I got it from support. Please help me INFINITY.
Old 05-28-2008, 19:23   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
This means that you need to use another flash file.
Did you tried this way ?
Old 05-28-2008, 22:39   #7 (permalink)
Member: 450871
Sonork: 100.1592197
Thanks Meter: 121
Originally Posted by InfinitySupport View Post
Hello,
Yes Sir, I tried three different files with no success. I already sent to you an original backup before flashing couse soft detected it as new firmware.
Old 05-29-2008, 16:57   #8 (permalink)
Member: 130995
What was initial phone condition ?
Is it was working or dead phone ?
Old 05-30-2008, 04:40   #9 (permalink)
Member: 434480
Thanks Meter: 14
sorry i have problem with 6300 Q7+ with sim card phone is restart, i already succes format ffs in infinity but phone still restart and searching signal. Can you give me solutions for my problem ? I already backup eeprom and fullflash before format.
Thank you
Old 05-30-2008, 07:41   #10 (permalink)
Member: 130995
Thank you
Did you tried to make 112 (emergency) call without sim card ?
What is the results ?
Old 05-30-2008, 07:55   #11 (permalink)
Member: 434480
Thanks Meter: 14
i can get mailbox service if i call 112. Can You hel[p me?
Tahnk you
Old 05-30-2008, 08:06   #12 (permalink)
Member: 130995
Make "ffs format" and then repair imei.
Old 05-30-2008, 09:55   #13 (permalink)
Member: 434480
Thanks Meter: 14
ok thank you very much
Need create a ask file but give error ct3im Federal One 2 12-14-2007 04:25
nokia 6300 Q7+ gsm_enggine Infinity-Box 7 11-16-2007 23:54
Pliz asisst with 6300 Q7 flash file MichieMax Various 0 10-29-2007 15:26
chinese nokia 6300 Q7 ahmad bashir Chinese Cocktail 1 10-04-2007 18:56
3200 give error but unlock! why? sergioems Trisha & Matrix Flasher 13 12-26-2003 18:38
Page generated in 0.23318 seconds with 9 queries
