12-06-2007, 15:05 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: malaysia Age: 40
Member: 224312 Status: Offline Thanks Meter: 13 | 6300 Q7 how to format and when i connect to the box should i insert battery?? |
12-06-2007, 15:34 | #2 (permalink) |
Freak Poster Join Date: Sep 2006 Location: syria damascus
Member: 348451 Status: Offline Thanks Meter: 2 | first of all u should use battery then try to switch the tx and rx and bowr the phone when the software aska you if u have other questions contact me on my messenger |
12-06-2007, 16:01 | #5 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: india ( Gujarat )
Member: 370998 Status: Offline Sonork: 100.1582579 Thanks Meter: 219 | Quote:
2. coneect RJ45 2nd pin to RX shown on the phone pcb 3. connect RJ45 3rd pin to TX shown on the pcb 4. Connect RJ45 7th and 8th pins to GND ( on the negative on the pcb ) 5. Try to Formatt FFS 6. power on from power on/off switch ( on the top side don't press Red swith from keypad ) press for 30-40 second chandresh swami | |
12-06-2007, 16:17 | #6 (permalink) | |
Member: 224312 Status: Offline Thanks Meter: 13 | Quote:
12-08-2007, 09:26 | #8 (permalink) |
Member: 224312 Status: Offline Thanks Meter: 13 | SIR....... I HAD FOLLOW THE INSTRUCTION U TEACH AND LSO CHECK MANY times that the pinout i connect is correct but every time when i press read information from phone also show that process fail..... the below is the test result i got.... results (1) : 1. coneect RJ45 2nd pin to RX shown on the phone pcb 2. connect RJ45 3rd pin to TX shown on the pcb 3. Connect RJ45 7th and 8th pins to GND ( on the negative on the pcb ) (below the rx point) 4. press the button read info form phone 5. power up the phone (at this my phone will power up but once power up, it will shows battery low and auto shut down) 6. than it will shows process fail.... results test (2) . coneect RJ45 2nd pin to TX shown on the phone pcb 2. connect RJ45 3rd pin to RX shown on the pcb 3. Connect RJ45 7th and 8th pins to GND ( on the negative on the pcb ) (below the rx point) 4. press the button read info form phone 5. power up the phone (at this my phone will power up and just shows the icon handfress only, it will not auto shut down but nothing happen,) 6. than it will shows process fail.... can any one teach or tell me why??? i just brought this infinity box few days... i had tried it will phone motorola, panasonic, lg and alcatel but no problem, it just give me this 6300 Q7+ problem only....... pls advice and teach me how..... thanks you... |
12-08-2007, 09:53 | #9 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
12-08-2007, 19:42 | #11 (permalink) | |
At first check, what is CPU name in your phone. If phone CPU name is like MT62xx thos CPU is supported, and you must follow to instructions how to find pinout. If CPU chip is not like MT62xx this CPU is not supported yet. | |
12-08-2007, 20:30 | #12 (permalink) |
Member: 224312 Status: Offline Thanks Meter: 13 | sir, i had found the problem, just the cable problem i got......... but now i cannot format the ffs.... when i press ffs igot this: press and hold power button now ! 9600 error: boot phase#2/1 failed can't intialize test mode ! possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method operation failed ! finished, time used: 22 sec remove/install battery now ! wat can i do?? thanks you...... |
How to rip and edit DVD movies to other video formats | ulove285 | Off Topic Zone | 0 | 02-11-2010 07:59 |
How to know and when we have to use ASK/RPL operation ????? | tsarkh | Infinity-Box | 2 | 10-03-2007 14:34 |
I need help , i have COM port connection and i can't connect to the phone | starmad | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 10-01-2004 20:11 |
I need help , i have COM port connection and i can connect to the phone | starmad | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-01-2004 17:25 |
