11-21-2008, 09:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 73455 Status: Offline Thanks Meter: 23 | 6300 rm-217 dead set br thnks. COM25 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:FF8A:6989 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 230400 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2B0000EA18F09FE118F09FE118F09FE118F09FE118F09FE1 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98004900000002:2BEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................................................. ...... can't detect fat record name location ffs element #1 detection failed detecting ffs structure pass 2... .................................................. ...... can't detect fat record name location ffs element #2 detection failed Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 171 sec Remove/Install battery now ! |
08-01-2009, 05:15 | #4 (permalink) |
Freak Poster Join Date: Jul 2006 Location: indian ocean
Member: 320858 Status: Offline Sonork: 100.1602961 Thanks Meter: 25 | cant flash 6300 chinese 1. it was turning off 2. I did ffs safe mode format an it was not turning of but no network. 3. I tried flashing with a flashfile I read from another phone of the same type. here is the log. Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.73 S/N: 296D:0112 Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... flash[K300_PCB01_GPRS_MT6225_S00.MT6225_GEMINI_V1_00.BIN]_20090718-144041.B0M.bin loaded identification#1 protocol ver: 04 ver. sw 1: K300_PCB01_GPRS_MT6225_S00.MT6225_GEMINI_V1_00.BIN ver. sw 2: MT6225_GEMINI_V1.00, 00000000 ==== log: [7/29/2009 1:27:55 PM] ==== COM10 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7F03:0008 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_1_2_ 3_2.BIN ver. sw 2: sygj.6300.1.2.3.2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_1_2_ 3_2.BIN]... file saved: D:\china 6300\eeprom[MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_1_2_ 3_2.BIN]_20090729-133207.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware error: error# 0000FFFF error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 303 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? I pressed no could some one pliz advise me on how to proceed now it cannot flash. now iget this module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7F03:0008 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98000300000001:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090729-134228.B0E.bin flash: 98000300000001:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 98000300000001:FFFFFF00000000 Write: Firmware error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 error: error# 0000FFFF error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 360 sec Remove/Install battery now ! |
The Following User Says Thank You to Alfarouk For This Useful Post: |
08-01-2009, 23:50 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what cable do you use as interface? did you try latest CM version 2,87? |
08-03-2009, 04:23 | #6 (permalink) |
Member: 320858 Status: Offline Sonork: 100.1602961 Thanks Meter: 25 | solder on board on the m.board it shows rx tx and ground it reads very well and the version is that comes with the latest infinity main setup. thanks |
08-03-2009, 07:37 | #7 (permalink) |
No Life Poster Join Date: Jul 2005 Location: sarcelles Age: 47
Member: 161061 Status: Offline Thanks Meter: 568 | do you tell me what is correspondent firmware read information and post here ihave whole chip and now i can't know the good firmware Last edited by ::. zine .::; 08-03-2009 at 07:44. |
The Following User Says Thank You to ::. zine .:: For This Useful Post: |
Nokia 6300 RM-217 dead USB flash problem need help | ar_memon2 | Nokia Base Band 5 ( BB-5 ) | 9 | 07-25-2011 11:19 |
Nokia 6300 RM-217 DEAD USB FLASH FAULTY!!! | Mr.Ultimate | Nokia Base Band 5 ( BB-5 ) | 5 | 11-26-2009 19:36 |
6300 [Rm-217] dead after flash with hwk | TUR@N ALAM | HWK | 3 | 10-11-2008 06:06 |
Nokia 6300 RM-217 DEAD USB FLASH FAULTY!!! | Mr.Ultimate | J.A.F. By Jafsupport.com | 5 | 01-15-2008 00:41 |
