12-29-2016, 23:02 | #1 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,256 | 7043A Error Flash Write Flash Error Quote:
12-30-2016, 07:44 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | have same problem Operation : Flash [ v1.07 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 088F9E51 ID_BLOCK_I : 007050E1 ID_BLOCK_L : F8C7965F8174357D8E734D18C5FD22E0 ID_BLOCK_L : DD5ACE0A92B110126300A13B0300642C Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 31 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : 16384 bytes received,2sectors more to go Flash Error , Wrong ACK message! Bad File or eMMC fault? Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
01-14-2017, 08:50 | #4 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | mr wait solved this version 1.09 have same error Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : TCL Device Manufact.: TCL Device Model : alto5 Device CPU : MSM8916 Device IntName : 7043A Device Version : 5.0.2 CU_SWVer : TCL Device Compile : 29/04/2015 12:29:23 p.m. Device ExtInfo : 7043A Load Ok! Operation : Flash [ v1.09 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 088F9E51 ID_BLOCK_I : 007050E1 ID_BLOCK_L : F8C7965F8174357D8E734D18C5FD22E0 ID_BLOCK_L : DD5ACE0A92B110126300A13B0300642C Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 31 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : 16384 bytes received,2sectors more to go Flash Error , Wrong ACK message! Bad File or eMMC fault? Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
02-03-2017, 00:46 | #6 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | version cm2 qualcom 1.10 wait repair this Card found : 57FB1594 , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.10 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : TCL Device Manufact.: TCL Device Model : alto5 Device CPU : MSM8916 Device IntName : 7043A Device Version : 5.0.2 CU_SWVer : TCL Device Compile : 29/04/2015 12:29:23 p.m. Device ExtInfo : 7043A Load Ok! Operation : Flash [ v1.10 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 087E7F10 ID_BLOCK_I : 007050E1 ID_BLOCK_E : 087E7F10 ID_BLOCK_L : 3B06579C40B7F4BECDB2B2D9043EE123 ID_BLOCK_L : C24BDF1583AE212D7411B20A32170B3B Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 31 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : 16384 bytes received,2sectors more to go Flash Error , Wrong ACK message! Bad File or eMMC fault? Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash [ v1.10 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 087E7F10 ID_BLOCK_I : 007050E1 ID_BLOCK_E : 087E7F10 ID_BLOCK_L : 3B06579C40B7F4BECDB2B2D9043EE123 ID_BLOCK_L : C24BDF1583AE212D7411B20A32170B3B Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 31 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : 16384 bytes received,2sectors more to go Flash Error , Wrong ACK message! Bad File or eMMC fault? Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
02-03-2017, 01:21 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I still waiting when such device will arrive in my hands. Hope in near 3-4 days have it. |
08-15-2017, 16:34 | #8 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Faisalabad Pakistan
Member: 696491 Status: Offline Thanks Meter: 164 | one more request to solve this problem .. plzz Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 0C3C52D3 ID_BLOCK_I : 008110E1 ID_BLOCK_L : D0104AB4238FB4B790C50F10DFAA2A22 ID_BLOCK_L : 176ED07B7CE757DCF13C914E44AB4586 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : Huawei ProdName : Y530-U00 ProdModel : HUAWEI Y530-U00 Device : Y530-U00 AndroidVer: 4.3 Manufact. : HUAWEI SysPatch : HuaweiY530-U00 QLMxCPU : MSM8610 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Flash [ v1.14 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 0C3C52D3 ID_BLOCK_I : 008110E1 ID_BLOCK_L : D0104AB4238FB4B790C50F10DFAA2A22 ID_BLOCK_L : 176ED07B7CE757DCF13C914E44AB4586 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Flash Chain : 27 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : Read back verify failed at sector -1958152192,num sectors 0 Flash Error , Wrong ACK message! Bad File or eMMC fault? Error : Flashing failed! Check previous message for more info! Last edited by netvision123; 08-15-2017 at 16:36. Reason: adding |
12-19-2017, 11:47 | #9 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Earth Age: 24
Member: 2425283 Status: Offline Thanks Meter: 95 | Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 06A06592 ID_BLOCK_L : 17D18B73E24875702F04CCD11E65EDDD ID_BLOCK_L : 7B0AB417188B33B055A0F52220CFD9E2 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Flash Chain : 27 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : Read back verify failed at sector 2113210521,num sectors 0 Flash Error , Wrong ACK message! Bad File or eMMC fault? ERROR : Flashing failed! INFO : Check previous message for more info! |
