02-22-2008, 16:49 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 402331 Status: Offline Thanks Meter: 0 | 8600 luna serial cable help Can anyone show me how to make of were to buy? the only thing i have now is tha CA101 usb cable. Thank you already |
02-22-2008, 18:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market. Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
02-22-2008, 21:02 | #3 (permalink) |
Member: 402331 Status: Offline Thanks Meter: 0 | This are some photos of my phone, Its a Nokia luna 8600, the cable i got with it is usb to microUSB See the photo. I do not have a photo of a PCB and i dont know where to find the TX RX and ground. I have been reading alot, and readed that some people bought a motolla C115 serial cable then cut the pin, get 3 wire white and blue and black. black is ground white is RX blue is TX But how will i connect this to the micro usb ? i do not understand Thank you already, for all the help |
02-22-2008, 21:13 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, According to your question you must read little bit more than you have read already. Please, start your new reading from FAQ thread: http://67.15.194.130/vbb/showthread.php?t=342807 You will find there thread "how to build cable" |
02-22-2008, 21:42 | #5 (permalink) |
Member: 402331 Status: Offline Thanks Meter: 0 | Thank you for your super fast replay, Is it posible to find it out without skrewing open the hole phone? i found this also 8600 Luna like original: 8+11+12 GND 9 TX 10 RX Can you maybe draw me a simple picture how to do it? |
02-22-2008, 22:25 | #6 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | have same sh*t to flash here test all posible combinations and dont suceed....if anyone have idea for pinout it will be great for sure pin1 is GND, pin5 is charger +, so i chcked all other pins and still can't boot this "phone" BR |
02-22-2008, 22:46 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @tostefo open phone and try to find Rx/Tx testpoints on phone PCB @dead12 just read FAQ once again and you will see detailed instruction regarding own cable creation. |
02-23-2008, 04:07 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Yes, I see you are really tired to read, probably it was the only reason my advice ignorance. Ok, it's not a problem. Users always busy but we are always free, so we can make "search" and find required links w/o any problems. Please, dear tired friend, read this instruction with pictures: http://67.15.194.130/vbb/showthread.php?t=386780 btw, what is "picture of the inside of the phone straigt from the factory" ? To be honest I can't understand what factory pictures you talk about. |
02-23-2008, 09:09 | #10 (permalink) |
Member: 402331 Status: Offline Thanks Meter: 0 | i see what you mean my friend, and i already found those pictures but that means that i have to stick it right onto the board, is it not posible to do trough the micro usb? thank you |
USB <-> Serial Cable Help!!! | Dr-celular | Universalbox | 2 | 09-30-2009 07:42 |
Nokia 8600 Luna Chinese LCD - Help | forgez | Nokia Hardware & Hardware Repair | 1 | 07-30-2008 17:49 |
8600 luna serial cable | dead12 | Chinese Cocktail | 0 | 02-22-2008 16:51 |
6800 luna serial cable | dead12 | SpiderMan | 0 | 02-22-2008 16:42 |
major problems with serial cables Help Please!>? | jmpmjmpm | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 01-15-2005 00:21 |
