03-08-2009, 22:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2003
Member: 26692 Status: Offline Thanks Meter: 51 | how to work with 1:1 copy of apple iphone? http://www.diytrade.com/china/4/prod...tml#normal_img http://www.tech-epoch.com/sdp/827994...6-1738000.html all is like original even conector.chargue with original usb but i tunes dont identify. have some little differences like sim case in original are prsent and in these sim input dicerctly and the reset buttom in side of phone.sw aparence too is like all chinesse phones. problem is have not signal and cant work with pind finder becouse dont have that conector. |
03-08-2009, 23:23 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
03-09-2009, 18:48 | #3 (permalink) | |
Member: 26692 Status: Offline Thanks Meter: 51 | Quote:
pind finder dont hat that. | |
03-10-2009, 11:18 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if phone can be powered from pinfinder power- we can assume that pinfinder failed to find pinout because there is no Tx/Rx in system connector. now you must look for test points on PCB. for this you might be need to disassemble phone |
03-10-2009, 16:25 | #5 (permalink) |
Member: 26692 Status: Offline Thanks Meter: 51 | no,no,no, i mean these iphone use same conector like original and pin finder dont have any cable like that.then maybe you will need a cable for next productions becouse will be more common. i think for now only way is try to find the signals using a original usb cable and making the own rj45 cable.(huff .is a lot of work) if some body have any data about i will be glad. |
03-11-2009, 21:52 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! analysing USB cable will not give any result. better to measure voltages on phone pins and detect Tx/rx by voltage 2,7-2,9 volts. full charged battery must be attached when you do measurments |
E71i DEAD TO HELP WITH TRYING TO REPAIR WITH FULL COPY OF FLASH | tecnicelltech | Infinity-Box | 5 | 08-01-2009 04:53 |
manual plz to how to work with binfinder usb` | melgsm | SpiderMan | 2 | 06-22-2008 10:36 |
How to work with Full flash in Samsung phones ! | GSM SNIPER | UFS2 + UFS3-Tornadoflasher | 3 | 01-30-2005 08:20 |
How to work with the terminator Step by step !! | GSM SNIPER | Sony Ericsson | 3 | 05-30-2004 11:54 |
How to work with autocal progs for Samsung - help need!!! | Sonia | VLSI, Conexant, Skyworks and Old Models | 1 | 11-10-2002 03:00 |
