Old 10-02-2005, 11:32   #1 (permalink)
Member: 122016
X70 unlock problem
Checking data, wait...
Device have to be SWITCHED OFF
Press Power button now...
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
SW Version: GAX70A3939041214
FLASH-ID: 10107E7E
Parameters Done
Check data...
STEP-01 in progress...
Check data Done
Check HW...
FLASH supported[10107E7E]
Check HW Done
Operation...
Working, don't interrupt...
Action-1 Failed[]
Operation Failed
Finished
i need help
Old 10-02-2005, 16:23   #2 (permalink)
Member: 59789
Thanks Meter: 16
same pro
here m8 i hope infinity team can reply asp
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
i will keep on trying with this untill someting happen.
Old 10-02-2005, 16:38   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
i need help
Hi,
What is with phone now ? Can it power-on or connect to software ?
Old 10-02-2005, 16:40   #4 (permalink)
Member: 130995
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
Hi,
Could you try to connect phone on other baud rate ?
Old 10-02-2005, 16:48   #5 (permalink)
Member: 59789
Thanks Meter: 16
Originally Posted by InfinitySupport
Hi,
thanks m8 but noting from these two 57600 & 115200 when i power fone noting happen.
Old 10-02-2005, 21:07   #6 (permalink)
Member: 122016
problem solved on another pc
Old 10-03-2005, 12:24   #7 (permalink)
Member: 130995
Hi,
What is this phone history ?
Is it was only one unlock attempt (your log posted here before) or it was other attempts ? If it's not first, give me, pls, previous logs.
Old 10-03-2005, 13:27   #8 (permalink)
Member: 59789
Thanks Meter: 16
Hi,
no m8 i try on two pc but here is my log from one pc
Log opened: [02/10/2005] [15:58:35]
App: C:\Program Files\InfinityBox\X70\X70_v105.exe
Current device: X70
Loading, wait...
Ready
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
Err: can't enter TestMode
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
Log opened: [02/10/2005] [16:04:47]
Current device: X70
Loading, wait...
Ready
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
Log opened: [02/10/2005] [16:43:56]
Current device: X70
Loading, wait...
Ready
Finished
Finished
Finished
Finished
Finished
Log opened: [02/10/2005] [16:52:40]
Current device: X70
Loading, wait...
Ready
Finished
Finished
Log opened: [02/10/2005] [16:58:46]
Current device: X70
Loading, wait...
Ready
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
Parameters Failed
Finished
thanks for ur help.
Panasonic X70 Unlocking Problems axilleask Griffin 3 11-18-2004 11:45
x70 unlocking problem Moosani Griffin 15 11-09-2004 08:50
x70 unlock problem dimon Griffin 2 10-21-2004 22:12
x70 unlock problem e_mobile Griffin 9 09-25-2004 03:42
Panasonic X70 unlock Problem kwh Griffin 11 06-01-2004 23:27
Page generated in 0.19463 seconds with 9 queries
