02-05-2006, 04:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: www.sw-box.com Age: 19
Member: 152573 Status: Offline Thanks Meter: 58 | a100 problem regards alex |
02-05-2006, 11:54 | #4 (permalink) |
Member: 152573 Status: Offline Thanks Meter: 58 | yup. i flash 3 part.. even try to flash eprom same problem.. sir, i just wanna know tis is software problem or lcd problem 1st regards alex |
02-09-2006, 11:26 | #6 (permalink) |
Member: 152573 Status: Offline Thanks Meter: 58 | COM5 selected Device: Panasonic A100,A101,A102 Checking data, wait... Action: Flash write Write: Firmware Write: MAP/Customization Write: Language Pack Skip: EEPROM Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E220A2201 Flash: 80E59F00000000 method: 03 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Erasing... Err: erase[02] Erasing Done Writing... Write: Firmware method: 03 Write: MAP/Customization method: 03 Write: Language Pack method: 03 method: 03 Writing Done Finished Remove/Install battery now ! Time used: 659 sec hi sir, still same problem.. izzit possible erase error made the phone become display panasonic logo for few seconds and after tat white screen? i flash with all epprom alreayd but still same problme.. regards alex |
02-10-2006, 04:07 | #8 (permalink) | |
Member: 152573 Status: Offline Thanks Meter: 58 | Quote:
regards alex | |
02-11-2006, 08:47 | #10 (permalink) | |
Device: Panasonic A100,A101,A102 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E220A2201 Flash: 80E59F00000000 method: 03 Boot Done Set baud... 460800 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Erasing... Err: erase[02] Erasing Done Writing... Writing Done Finished Remove/Install battery now ! Time used: 44 sec tis is log files for reset setting, same problem regards alex | |
02-11-2006, 08:49 | #11 (permalink) |
Member: 152573 Status: Offline Thanks Meter: 58 | COM5 selected Device: Panasonic A100,A101,A102 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E220A2201 Flash: 80E59F00000000 method: 03 Boot Done Set baud... 460800 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Erasing... Erasing Done Writing... method: 03 Writing Done Finished Remove/Install battery now ! Time used: 22 sec log files for unlock.. sir, i try all epprom repair and change lcd alreyad but still same problem.. hope can help me solve the problem regards alex |
02-11-2006, 12:16 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, It looks like it was small bug in QModule and as a result - it was not possible to reset A100 to defaults. Pls, download QModule v1.05 from support area. Try to make "Reset settings". waiting for results and log file after reset. |
04-27-2006, 09:12 | #15 (permalink) |
Junior Member Join Date: Jun 2003 Location: Firenze (Italy) Age: 42
Member: 30601 Status: Offline Thanks Meter: 0 | Before going crazy with boxes try this MASTER RESET: *01763*737381# I had 2 Phones A102 with white screen after logo, inserted the code, turn off and on the phone, and now both work perfectly!! |
All about a920 a925 a100 problem..please help us:( | Lampu | Motorola P2k | 1 | 06-21-2005 17:51 |
Panasonic A100 problems | mrmarcellos | Panasonic | 17 | 03-15-2005 11:26 |
A100 problem | MadPhone | UfoTools | 2 | 02-05-2005 04:23 |
A100 problem | jak2812 | Panasonic | 1 | 09-20-2004 22:31 |
A100 problem, never meet before | Headmade | VLSI, Conexant, Skyworks and Old Models | 3 | 10-15-2003 16:02 |
