08-26-2010, 21:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | a1000 want to fix calibreat touch screen but giving me error Code: COM3 [VCP0] selected module v3.19 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E103:0000 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 18 sec Remove/Install battery now ! salim |
08-27-2010, 09:34 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! with a help of this function you can only Disable touchscreen, not repair. to repair it you must access phone menu and do Manual Touchscreen calibration by touching Calibartion points with a pen Last edited by InfinityHelp; 08-28-2010 at 09:56. |
08-27-2010, 19:06 | #3 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | I think u want to bypass the touch screen and go to the home screen. If i am right.. 1, please use direct cable with infinity box(don't use pinfinder) 2. use fully charged battery. 3. when operation start press power button and hold , until it done. |
08-29-2010, 00:19 | #4 (permalink) |
Member: 160928 Status: Offline Thanks Meter: 338 | thats what i want to do i want to disable touch screen my touch screen is work but some how i can not disable every time i try to do give me error what i put in first post what should i do? |
08-29-2010, 02:23 | #5 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
thanks | |
08-29-2010, 07:38 | #6 (permalink) | |
Member: 950629 Status: Offline Thanks Meter: 105 | Quote:
1. Diassemble your phone. 2. You will see rx tx point on pcb. 3. Solder infinity free end cable rx tx to pcb rx tx point and solder gnd too. 4. Conect cable to infinity. 5. Insert battery. 6. Start the process again. | |
08-29-2010, 12:25 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please tell me about your main infinity box: is it modified to work with pinfinder better? for this you must remove and shortcut diode, this procedure you can find in Pifnidner User Manual trubleshooting section. after this is done- test mode will work much more better |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Tdb4 emulator wanted | Fk2 | Wanted Products | 0 | 06-01-1999 09:45 |
