12-28-2015, 15:57 | #1 (permalink) | |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | A106 Dead Preloader <New User> Need Help It is Micromax A106 dead here is logs of identify, Any chances of recovery? Quote:
12-29-2015, 11:55 | #5 (permalink) | |
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Init Preloder Give Following error Quote:
12-29-2015, 12:05 | #6 (permalink) |
No Life Poster Join Date: Jun 2012 Location: bhopal
Member: 1778370 Status: Offline Sonork: sujan_goa Thanks Meter: 66 | User selected Preloader file : preloader_s4700.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 90014A483847326404 , Name : H8G2d , Vendor : 90 , [HYNIX] FlashID [1] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040502A1F9B18131 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : 00000BC4 Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
12-29-2015, 12:57 | #7 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | p.k510 ur all post in cm2 section are just spam u have same problem as thread starter have problem and u post all logs copy from that plz jaydi check onec his all post and problem in cm2 section and i think he need check this onec http://forum.gsmhosting.com/vbb/f296...uters-2029472/ |
