a120 imei always not write other done Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048600A3CE7D4105 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3CE7D4105 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 28A4F1466874D510D2C088E08BFD82D0 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Burned OTP detected! Operation USELESS! Done! Elapsed: 00:00:05 Reconnect Power/Cable! plz tell me reason i,m wrong or this is bug sir |
other logs COM port searching and preloader handshake. Connect port COM9. COM port searching and preloader handshake. Connect successfully. CPU TYPE:MT6572, E01 DSP Firmware Version:2000.00.00 DSP Patch Version:1.0 Software Version:MOLY.WR8.W1315.MD.WG.MP.V1.P7 Hardware Version:TINNO72_WET_JB3_HSPA_HW Audio Version:Unknown IMEI1:invalid. IMEI2:invalid. >>IMEI success. |
SW wasn't read IMEI from OTP. Probably - it can be empty and made just to be. Need check FW. Also - does IMEI alive after factory reset? |
yes alive after reset problem came only a120 |
