05-04-2010, 13:05 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | A200 Still Same Problem i have download this forum N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_9_4__NKTEL-A200_w_eeprom.B0E i need this firmware N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN COM4 [VCP0] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4F03:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE50000130000001844 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.35577761.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN_8BBB2DD0].rpl rom info detection finished ==================== New firmware detected (v.3.13, database date: 25.04.2010): N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 35577761 rom info ver: 04 sw version: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN project-id: N66_ABROAD_5CDGB_S5LCD_V1.6.6, D02DBB8B code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_6_6__system_log_35577761_8BBB2DD0_20100504-152313.B0X.bin Finished, time used: 2 min 4 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-04-2010, 22:03 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! try this one: flashfiles/ChineseMiracle/_MT6225/N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6__NKTEL-A200_16m_En_Ru_El_Fr_Es_De_Th_Vn_Tr_Hi_Farsi_Ar.B0 M.bin |
05-06-2010, 13:24 | #3 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 992 | Quote:
COM4 [VCP0] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6__NKTEL-A200_16m_En_Ru_El_Fr_Es_De_Th_Vn_Tr_Hi_Farsi_Ar.B0 M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4F03:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: 35577761 rom info ver: 04 sw version: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN project-id: N66_ABROAD_5CDGB_S5LCD_V1.5.6, 299AD4E2 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.35577761.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN_E2D49A29].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.35577761._N66_ ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S5LC D_V1_5_6.BIN_E2D49A29_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.35577761.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN_E2D49A29].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.35577761._N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_A BROAD_5CDGB_S5LCD_V1_5_6.BIN_E2D49A29_.rpl ==================== warning: unknown rom info structure: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN_E2D49A29 Unknown firmware detected (v.3.13, database date: 25.04.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed detecting startup code area #2... startup code area #2 is absent You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 37 sec Remove/Install battery now ! ==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [5/6/2010 5:17:49 PM] ==== firmware database date: 25.04.2010 Loading data, wait... [Infinity Box] Chinese Miracle v3.13 smart-card: connected S/N: 2A06:0116 Wait... Device: Autodetect 6205-6227 NOR Done ==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [5/6/2010 5:18:18 PM] ==== firmware database date: 25.04.2010 Loading data, wait... [Infinity Box] Chinese Miracle v3.13 smart-card: can not be found/connected error: Dongle is not found Dongle is not found ! Connect Dongle and restart software. ==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [5/6/2010 5:18:48 PM] ==== firmware database date: 25.04.2010 Loading data, wait... [Infinity Box] Chinese Miracle v3.13 smart-card: connected S/N: 2A06:0116 Wait... Device: Autodetect 6205-6227 NOR Done Repair Security Code COM4 [VCP0] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4F03:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: 35577761 rom info ver: 04 sw version: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN project-id: N66_ABROAD_5CDGB_S5LCD_V1.5.6, 299AD4E2 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.35577761.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN_E2D49A29].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.35577761._N66_ ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S5LC D_V1_5_6.BIN_E2D49A29_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.35577761.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN_E2D49A29].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.35577761._N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_A BROAD_5CDGB_S5LCD_V1_5_6.BIN_E2D49A29_.rpl ==================== warning: unknown rom info structure: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN_E2D49A29 Unknown firmware detected (v.3.13, database date: 25.04.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_6.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range Finished, time used: 1 min 36 sec Remove/Install battery now ! | |
05-06-2010, 17:23 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, Please, send this file to [email protected] C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_6_6__system_log_35577761_8BBB2DD0_20100504-152313.B0X.bin |
05-06-2010, 17:28 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! what about this one flashfiles/ChineseMiracle/_MT6225/N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_5_8__nktel-A200_16m_En_Ru_El_Fr_Es_De_Th_Vn_Tr_Hi_Farsi_Ar.B0 M.bin |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
DOES THE CELLNET DIGA HACK STILL WORK??? | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-04-1999 13:55 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
