10-13-2008, 10:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: egypt
Member: 309944 Status: Offline Sonork: 1628185 Thanks Meter: 40 | the phone starts its self and icant format it Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 101 sec Remove/Install battery now ! |
10-13-2008, 10:57 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | check the set without connecting VCC AND CNG connect the set with cable but not connect VCC AND GND cable and press format |
10-13-2008, 15:03 | #3 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
10-13-2008, 21:42 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | no, no, no guys! please see that MCU type detected is 6205! this is second MCU, which very rare need to be formated/flashed. i advice to find first MCU pinout and continue to work with it. if you sure that you need with second MCU- then you must keep power button pressed for about 40-50seconds. do not release it even if phone powers On- this is normal. first MCU starting, then will boot second |
Help,how to fix the phone with SD damaged and SL=0000000? | Smartmio | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-24-2010 11:26 |
nokia E61 phone start up failed and contact retailer please help | asif_ae | HWK | 1 | 11-13-2008 05:41 |
Can not flash the phone. I got everything and up to last step!!! help please | camel21 | Nokia Base Band 5 ( BB-5 ) | 0 | 07-15-2007 08:59 |
Samsung A300: stupid tone when the phone starts up | sgha300 | VLSI, Conexant, Skyworks and Old Models | 0 | 02-22-2002 08:26 |
