SLIPLOCK | 12-10-2009 07:51 | A380I soon supported?? 3 Attachment(s) Hi infinity lovers....
today i work on CECT A380I,
so i post here Pinout and picture of phone...
phone come to me with user code, according to cellhack post i build cable and reset ffs
you can found the log here and soon (when i found my rapidshare account) you will have eeprom and fullflash
wbr Code:
==== log: [09/12/2009 14:42:34] ====
COM3 [VCP0] selected
module v3.02
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:A041:AD40
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.25FFDBD1.[SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01.BIN_AAD12676].rpl
rom info detection finished
device-id: 25FFDBD1
rom info protocol ver: 04
ver. sw 1: SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01.BIN
ver. sw 2: D208-1M_G61v01.01b01, 7626D1AA
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01__fullflash...
file saved: F:\Documents and Settings\Administrateur\Bureau\a380i\SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01__fullflash_20091209-145104.B0M.bin
file saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01__system_log_25FFDBD1_AAD12676_20091209-145148.B0X.bin
Finished, time used: 550 sec
Remove/Install battery now !
module v3.02
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
high speed boot Off
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: D208-1M_G61v01.01b01
Version: G61_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 35522*********
connection Ok
building list...
done
items to clear: 177
warning: wrong packet cs
items cleared: 177 of 177
building list...
done
items remains: 0
Finished, time used: 63 sec
Remove/Install battery now ! |
