Old 12-10-2009, 07:51   #1 (permalink)
SLIPLOCK's Avatar
Member: 86301
Thanks Meter: 107
A380I soon supported??
Hi infinity lovers....
today i work on CECT A380I,
so i post here Pinout and picture of phone...
phone come to me with user code, according to cellhack post i build cable and reset ffs
you can found the log here and soon (when i found my rapidshare account) you will have eeprom and fullflash
wbr
==== log: [09/12/2009 14:42:34] ====
COM3 [VCP0] selected
module  v3.02
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:A041:AD40
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.25FFDBD1.[SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01.BIN_AAD12676].rpl
rom info detection finished
device-id: 25FFDBD1
rom info protocol ver: 04
ver. sw 1: SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01.BIN
ver. sw 2: D208-1M_G61v01.01b01, 7626D1AA
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01__fullflash...
file saved: F:\Documents and Settings\Administrateur\Bureau\a380i\SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01__fullflash_20091209-145104.B0M.bin
file saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\SIMC26_06B_PCB01_GPRS_MT6226_S01.D208-1M_G61V01_01B01__system_log_25FFDBD1_AAD12676_20091209-145148.B0X.bin
Finished, time used: 550 sec
Remove/Install battery now !
module  v3.02
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
high speed boot Off
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: D208-1M_G61v01.01b01
Version: G61_HW
detecting structure #2...
 0 done
44 byte(s) read
imei: 35522*********
connection Ok
building list...
done
items to clear: 177
warning: wrong packet cs
items cleared: 177 of 177
building list...
done
items remains: 0
Finished, time used: 63 sec
The Following User Says Thank You to SLIPLOCK For This Useful Post:
Old 12-15-2009, 05:07   #3 (permalink)
SLIPLOCK's Avatar
Member: 86301
Thanks Meter: 107
@infinity team
are you interrested by this flash file?
if not let me know, i will remove from my rapidshare acount
wbr
Old 12-15-2009, 22:56   #4 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
program di dnot detect is as Unknown firmware, which means that we have this firmware in our collection.
thank you, and you can remove it
konka e303 soon supported? ;) SLIPLOCK Infinity-Box 7 12-11-2009 11:07
SPD comming soon supported ?? kimocyc Infinity-Box 3 06-23-2009 18:26
how soon support for k700i will come? doctorvatson Cruiser Suite 3 06-22-2004 07:58
z1010 support coming soon??? fuzionGSM Cruiser Suite 0 06-17-2004 21:56
DIV Will soon Stop support the aged consumer segsm Sony Ericsson 14 10-27-2003 23:56
Page generated in 0.36005 seconds with 9 queries
