01-19-2009, 12:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 883688 Status: Offline Thanks Meter: 12 | A8000 flash file neede SIMC26_06B_PCB01_GPRS_MT6226_S01.M332TL_M332CV01_0 1B02 No name on Phone behind the phone i can fount Model:A8000 its a dual sim MT6226BA CPU. |
01-20-2009, 00:00 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! unfortunately, we dont have such file in our collection. have you tried to solve your problem with format FFS? |
01-20-2009, 17:02 | #4 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Quote:
Now its turn to help other Infinity-Box users. So now please read full flash backup with Infinity-Box and send it to Infinity-Support via email, in this way other users can also get benefit from your file. Best Regards! yawarniazi | |
01-20-2009, 19:17 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello guys!! mr. yawarniazi is totally right, please, if possible send good working dump to [email protected]. include full phone model name. thank you!! |
10-16-2009, 21:07 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
you can try to search our suport area for smae version files. at the end of file you will see language tags. you need "PL" also we have separatly sold Language Editor tool. using it you can add language to any MT62xx family phone. more information you can find here: http://www.infinity-box.com/addon/in...langedit&lg=en | |
11-01-2009, 22:44 | #12 (permalink) |
No Life Poster Join Date: Mar 2007 Location: PL Age: 44
Member: 477842 Status: Offline Thanks Meter: 80 | yes, but I have problem with comunication with A8000 and Pinfinder , here is the log Cable 18A software version: 1.20 cable type: 1x18 (L18A) platform: MT: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 146 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") I try with battery in phone, and phone was power on, and power off in my second try so what`s is the problem ? pinfinder calbes or phone ? |
11-02-2009, 17:48 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i dont think this is a cables fault. lets start from beginning: do you able to power On this phone using pinfinder power? this is a main rule for success pinout search |
11-02-2009, 21:14 | #14 (permalink) |
Member: 477842 Status: Offline Thanks Meter: 80 | IN Pinfinder, when I connect L18A pinfinde cable to power on phone, phone always power off ? maybe I have cable problem ? because I have the same result on A8000 and CECT V68 |
11-02-2009, 22:53 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! I just had same phone. with cable inserted it started to consume too much power. I solved it this way: attached battery, powered On phone and found pinout in "CPU independent mode" the only thing which you must do- find some grounded phone part and attach there negative (black) power crocodile. if you dont have GND part available i would advice to use thin wire from negative battery terminal |
pls help need file haier c2010 spansion chip flash file need | @@@___@@@ | Various CDMA/TDMA Cell Phones | 1 | 02-26-2010 17:15 |
k510i flash file needed in support site no have any file in hwk ufs | shani72 | Sony Ericsson Hardware Repair | 0 | 12-04-2009 11:57 |
need 2280 reliance ufsx flash file need urgent | vinay_sharma | Nokia CDMA | 3 | 08-24-2007 07:18 |
@lead sir w600i flash file need for flash | cellworld | Cruiser Suite | 1 | 12-30-2005 06:10 |
v550 flash files need smart clip arapisch flash need | mobilerepair1 | Smart-Clip | 3 | 04-19-2005 00:12 |
