06-28-2010, 05:56 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | A903_s04_pcb01_gprs_mt6226_s01.a903_s04_v200.bin Thank you. LINK is: RapidShare: 1-CLICK Web hosting - Easy Filehosting log: COM26 [VCP0] selected module v3.12 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B81A:0AFF status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E7475E40.[A903_S04_PCB01_GPRS_MT6226_S01.A903_S04_V200.BIN_E 328BE7B].rpl rom info detection finished ==================== New firmware detected (v.3.12, database date: unknown): A903_S04_PCB01_GPRS_MT6226_S01.A903_S04_V200.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: E7475E40 rom info ver: 04 sw version: A903_S04_PCB01_GPRS_MT6226_S01.A903_S04_V200.BIN project-id: A903_S04_V200, 7BBE28E3 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ....................... detect standard ffs/eeprom location pass #1... .................................................. ...... detect extended ffs/eeprom location pass #1... .......................................... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: A903_S04_PCB01_GPRS_MT6226_S01.A903_S04_V200.BIN detecting firmware build... .................................................. firmware build: `‚;05AH600060403I720_S143HARRY6217_05A_HW2006-04-0316-55 detecting product-id... .................................................. .............. done detecting languages... ...................................... language parameters detected detected languages: En Fr Ml Th Tr Farsi Ar file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 903_S04_PCB01_GPRS_MT6226_S01.A903_S04_V200__syste m_log_E7475E40_E328BE7B_20100626-165120.B0X.bin Finished, time used: 1 min 44 sec Remove/Install battery now ! |
06-30-2010, 04:23 | #3 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Yes. I have to see network i says NO network FOUND !! and i have rewrite the imei !! Still the same !! The mobile is BRAND new !! Can you check if the eeprom in the flash file is OK !! |
